mikuni flat slide 34mm
- testarossa
Re: mikuni flat slide 34mm
02 Mar 2011 07:50
It doesn't take much bike to throw you off the high side when the tire grabs. Case in point:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
02 Mar 2011 09:11
Stu Pidasole wrote:
dont forget track conditions,air pressure in tire,clutch slipping,reaction time........... :woohoo:
a 2 degree change either way in air temp throws that out the window! :laugh:Using a et calculator bike and rider at 760 lbs with 100 horses I get 11.99 in the quarter.
- racer54
02 Mar 2011 17:16
I have personally seen a stock KZ1000 run 12.3-12.5 e.t.'s. Not a common sight though. Have also seen similar bike with different rider running in the mid-13's, so a lot is in the rider sitting behind the bars. I have had my 1075, 29 smoothies, V&H street header with baffle in, otherwise stock motor and stock wheelbase in the 11.4's but usually in the 11.7-11.8 range with an occasional 11.6 thrown in there to confuse me. I KNOW there is more there but that poor 130/18 tire can't handle much more then that. That's with a 720 lb. bike and rider. I need to check my cams as I know they are retarded (no wisecracks! lol) but not sure how much. That's in mid-summer heat around 90*. Many years ago, guys around here were running 11.8's consistently with KZ1000's with only a header and a slick...no bars and otherwise stock...motor and chassis except for struts.
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
02 Mar 2011 17:21I have personally seen a stock KZ1000 run 12.3-12.5 e.t.'s. Not a common sight though. Have also seen similar bike with different rider running in the mid-13's, so a lot is in the rider sitting behind the bars. I have had my 1075, 29 smoothies, V&H street header with baffle in, otherwise stock motor and stock wheelbase in the 11.4's but usually in the 11.7-11.8 range with an occasional 11.6 thrown in there to confuse me. I KNOW there is more there but that poor 130/18 tire can't handle much more then that. That's with a 720 lb. bike and rider. I need to check my cams as I know they are retarded (no wisecracks! lol) but not sure how much. That's in mid-summer heat around 90*. Many years ago, guys around here were running 11.8's consistently with KZ1000's with only a header and a slick...no bars and otherwise stock...motor and chassis except for struts.
- 79MKII
- Love Them Kaws!
03 Mar 2011 07:54 - 03 Mar 2011 07:55
No eBay APP ID and/or Cert ID defined in Kunena configurationHere ya go! Old style but probably work well....
The Kaw List:
Last edit: 03 Mar 2011 07:55 by 79MKII.
- DoubleDub
03 Mar 2011 08:00
No eBay APP ID and/or Cert ID defined in Kunena configurationBut these are 10-15hp bolt on carbs, why would you go with anything else?
cgi.ebay.com/ebaymotors/KEIHIN-FCR-41-CA...de4d1#ht_2030wt_1116
- PLUMMEN
03 Mar 2011 08:12
yeah i bet ya those woould work really well on a 1428 with lots of compression and a really big set of cams! :laugh:
- DoubleDub
03 Mar 2011 08:17 - 03 Mar 2011 08:17
No eBay APP ID and/or Cert ID defined in Kunena configurationStu - maybe you should build your engine from these...just need the internals and a head.
cgi.ebay.com/ebaymotors/Kawasaki-GPz-KZ-...sories#ht_526wt_1165
Last edit: 03 Mar 2011 08:17 by DoubleDub. Reason: ebay thingy
- PLUMMEN
03 Mar 2011 08:21
i bet even a combination like this runs good at a certain rpm range,im guessing its somewhere between 8500-9000 though! :woohoo:
- DoubleDub
- DoubleDub
03 Mar 2011 11:36
No eBay APP ID and/or Cert ID defined in Kunena configurationStu - these RS34's are looking quite a bit cheaper at the moment....
cgi.ebay.com/ebaymotors/Mikuni-34-radial...ewItem#ht_500wt_1088
