mikuni flat slide 34mm
- lemo32
- The Price of Cool aint cheap
Re: mikuni flat slide 34mm
01 Mar 2011 18:17
Pump gas 150 h.p. kz not going to happen. Turbo maybe.
1979 kz 1000 06 katana 750
- PLUMMEN
01 Mar 2011 18:30
my 1327 made 130 plus at rear wheel with a tire that was slipping badly on the drum to put it mildly,rubber shrapnel would be a better description! :woohoo:
that was on pump gas with home brewed go juice added to it,id say it put 140-150 to the ground with a good tire.
an 1197 turbo could easily put 150 to the ground without breaking a sweat,id say close to 200 with boost pumped up
- lemo32
01 Mar 2011 18:37
Talk is Talk, show me a dyno, 130 isnt 150, turbo yeah That I can believe, proof is in da puddin
- lemo32
01 Mar 2011 18:39
I think we need a new thread 150 h.p. no turbo kz is it possible lol
- PLUMMEN
01 Mar 2011 18:41
you did notice where i said 1327,no 1015 right? :laugh:
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
01 Mar 2011 18:54 - 01 Mar 2011 18:57
1075 kit, rs 34mm carbs, z2 cams, cam springs, Larrys street port job, welded crank, cut tranny, 180 tire on stretched swing arm, dyna 2000 ignition, 17 front 41 rear sprockets, V&H 4 to 1...........whats it run in the 1/4 mile?
Last edit: 01 Mar 2011 18:57 by Stu Pidasole.
- PLUMMEN
01 Mar 2011 18:57
depends on whos riding it! :laugh:
- Stu Pidasole
01 Mar 2011 18:58 - 01 Mar 2011 18:59
PLUMMEN wrote:
someone who started drag racing jr dragsters and still races for NHRA, but no bike riding.:laugh: still lets see some guesses.depends on whos riding it! :laugh:
Last edit: 01 Mar 2011 18:59 by Stu Pidasole.
- lemo32
01 Mar 2011 18:59
would be lucky if you got in the low 11s :S
- Stu Pidasole
01 Mar 2011 19:06
lemo32 wrote:
low 11's huh? whats a stock one run?would be lucky if you got in the low 11s :S
- PLUMMEN
01 Mar 2011 19:06
start out in the low 13s and work your way down the ladder! :laugh:
learn to ride and stop on the street before you worry about trying to run it on the track.
cant wait for spring ,i see a lock up clutch and a wheelie bar in my bikes near future! :woohoo:
- Stu Pidasole
01 Mar 2011 19:08 - 01 Mar 2011 19:11
PLUMMEN wrote:
trust me i wont be taking it down the 1/4 until i feel comfortable. low 11's is fast imo. my 68 468 camaro runs 10.29 at 129 mph.start out in the low 13s and work your way down the ladder! :laugh:
Last edit: 01 Mar 2011 19:11 by Stu Pidasole.
