mikuni flat slide 34mm
- PLUMMEN
Re: mikuni flat slide 34mm
01 Mar 2011 19:12
hell 13s are fast when youre out of control!
and 6.18 at around 115 in the 1/8 is really freaking scary on a no bar bike with an itty bitty 3" over arm! :woohoo:
- porchev914
01 Mar 2011 19:14
I believe stock is somewhere in the 12's.
FRANKEN Z!
- beefsquasher
01 Mar 2011 19:15
Still like 'em.
Larry - not to hijack the thread, but my carbs clack no matter how close I set up the synch. I set the synch mechanically on the bench with 4 equal ball bearings that fall through the slides as i slowly crank open the idle adjuster. Set 'em so thEy all fall through at the same time.
I can't seem to set them with a vacuum gauge rack because as soon as I remove the top cover on a particular carb, air leaks past the sides of the slide and changes how that cylinder runs. What am I missing?
-Dave
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
01 Mar 2011 19:16
PLUMMEN wrote:
note to self: when you get squirley let out of the gas slowely......:laugh: was thinking of the extensions for the arm, but ill wait till i drive it for a bit to see if its needed.hell 13s are fast when youre out of control!
- PLUMMEN
01 Mar 2011 19:17
porchev914 wrote:
with a really good rider on a perfect track....... :laugh:I believe stock is somewhere in the 12's.
- Stu Pidasole
01 Mar 2011 19:18 - 01 Mar 2011 19:19
porchev914 wrote:
like everything else in life....i guess ill just have to find out.
i have read 11's-13's stock. i guess theres too many factors. wieght of rider, track conditions, altitude.......:dry:I believe stock is somewhere in the 12's.
Last edit: 01 Mar 2011 19:19 by Stu Pidasole.
- lemo32
- The Price of Cool aint cheap
01 Mar 2011 19:21
note to ones self when sh@t gets to deep put on boots and walk lightly :laugh:
1979 kz 1000 06 katana 750
- PLUMMEN
01 Mar 2011 19:21
Stu Pidasole wrote:
yeah be really carefull about backing out of throttle going down track,things go from bad to worse really fast! :SPLUMMEN wrote:note to self: when you get squirley let out of the gas slowely......:laugh: was thinking of the extensions for the arm, but ill wait till i drive it for a bit to see if its needed.hell 13s are fast when youre out of control!
- PLUMMEN
01 Mar 2011 19:24 - 01 Mar 2011 19:31
lemo32 wrote:
springs a comin,come on down! :laugh:note to ones self when sh@t gets to deep put on boots and walk lightly :laugh:
Last edit: 01 Mar 2011 19:31 by PLUMMEN.
- lemo32
01 Mar 2011 19:32
would have to come up, I think the old suzi could give that mean old kaw a run for her money, but I don't know that 150 h.p. might run off and leave me :laugh:
- Stu Pidasole
01 Mar 2011 19:33 - 01 Mar 2011 19:34
PLUMMEN wrote:
when trauma hawk comes its sad....but when they come and leave without landing its death.
i hear you guys. im all about safety. i know its scary but i used to tech in bikes and cars at moroso for years. plus raced nhra and now also ihra. seen lots of crashes and close calls. makes your heart stop when your at the end of the track and a car hits the wall at 200 plus. my brother and i were 15 foot from the wall, and let me tell you........i grabbed him and ran my ass the other way.:ohmy:Stu Pidasole wrote:yeah be really carefull about backing out of throttle going down track,things go from bad to worse really fast! :SPLUMMEN wrote:note to self: when you get squirley let out of the gas slowely......:laugh: was thinking of the extensions for the arm, but ill wait till i drive it for a bit to see if its needed.hell 13s are fast when youre out of control!
Last edit: 01 Mar 2011 19:34 by Stu Pidasole.
- PLUMMEN
01 Mar 2011 19:36
well come on down and we'll see what happens! :laugh:
theres a couple of harleys running 5.80s that i stay away from like the plague though! :laugh:
im gonna run lock up clutch this year so i can spend less time smoking clutch trying to hold it down
