mikuni flat slide 34mm
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
28 Feb 2011 06:37
whats the story with these carbs? was thinking about buying a set.
- porchev914
Re: mikuni flat slide 34mm
28 Feb 2011 07:30
They are probably not the best place to put your money on a nearly stock engine. You will want to consider cleaning up the stock carbs and running them until you learn how to ride
FRANKEN Z!
- meds
28 Feb 2011 07:36
porchev914 wrote:
Hater!
Dont they use those on the gsxr 600 suzukis,How do you know who can ride?They are probably not the best place to put your money on a nearly stock engine. You will want to consider cleaning up the stock carbs and running them until you learn how to ride
Hater!
- porchev914
28 Feb 2011 07:59
Meds, did you wake up this morning on the wrong side of Joes bed? :blink: :laugh:
FRANKEN Z!
- PLUMMEN
28 Feb 2011 08:14
:woohoo:
- Stu Pidasole
Last edit: 28 Feb 2011 11:16 by Stu Pidasole.
- beefsquasher
28 Feb 2011 10:47
I have had them on my bike since I got it. No doubt in about a day or two you will have about a million people telling you that they are too big, you should get some super expensive 29mm or 33mm round slides or even CV carbs (BARF!). Don't waste your money or time. Get the RS34 carbs. They are cheaper than most other performance carb options (beside barf-tacular CV carbs) and I have had NO problems with midrange or low end or tuning or anything like everyone always predicts.
They have accelerator pumps that are very adjustable - both onset and duration of squirt. Totally eliminates any response problems. The whole idea behind the accelerator pump is to use a bigger carb to get more top end without losing any of the crispness and response of a smaller carb.
Get them and put them on. You won't be disappointed. They worked great on my 1075 when it had a stock head and an Andrews 2x intake cam. They worked even better with bigger cams, and a ported head. Amazingly, they are very forgiving when it comes to jetting. I have changed the exhaust and baffling, changed air filters, compression, head porting, cams, basically everything. Jetting changes - zero.
I'm tired of everybody badmouthing these carbs saying they are drag race only, no passing power, and so on. And they sound cool as they clack away at idle (if you go for that sort of thing).
Just sayin'
-Dave
Just sayin'
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- beefsquasher
28 Feb 2011 10:49
What's your setup anyways? They can be a bit much for a bone stock engine (they will still work fine).
-Dave
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- Stu Pidasole
28 Feb 2011 11:15 - 28 Feb 2011 11:16
thanks dave. right now my head is stock. i am sending it out for a port and polish to 32mm. ganna buy the 34mm minunis and maybr run a k410 cam set. probably need ape valve springs too. 1015 will be getting a 1075 bore with new piston kit. good to hear you like em so much...Joe
- DoubleDub
28 Feb 2011 12:48
The head's going to Larry, right? I'd ask him what he would put on the head he's doing for you.
- Stu Pidasole
28 Feb 2011 12:51
DoubleDub wrote:
the head will be modified specifically for the carbs.The head's going to Larry, right? I'd ask him what he would put on the head he's doing for you.
- DoubleDub
28 Feb 2011 12:55
It sounded like it, I'm just saying the guy doing your head will probably be able to help you pick out carbs better than many of the rest of us since he'll be shaping and carving for a specific tune.
