1983 kz550 ltd problems
  • bvaleri
  • bvaleri's Avatar Topic Author
Re: 1983 kz550 ltd problems
01 Jan 2011 09:19
#419594
ya i think i read your post about that i will try something when i pull the carbs off im waiting for the float bowl gaskets but i think the post office lost them
  • bvaleri
01 Jan 2011 09:45
#419595
after adjustments to the idle screw and putting cardboard in front of the carbs i got it to start it idle really high and i could adjust it at that time but i noticed gas spit out all over the cardboard any ideas why that would happen?
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
01 Jan 2011 11:07
#419608
harm wrote:
That is the same thing i had. So 3 of your choke flaps came off and most likely went thru your motor. Typically this don't do too much damage but now you need to fill in the flaps somehow. I used a 2 part epoxy and it works great! The flap opening is now completely sealed so now i use the choke lever to adjust the choke position as it warms up.
Choke flaps came off and went through the motor??!!!?!?!
and it DOESN'T do much damage?? :blink: WHAT!?!?
How the $&#% does that happen????
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • TeK9iNe's Avatar
01 Jan 2011 11:19
#419610
It happens at very small throttle openings (like idle). Its no big deal.
Lots of explanation left out here... :P
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
01 Jan 2011 11:47
#419616
Yeah, oddly, I think I have at least one motor where the flaps went through it. I don't know how the flaps make it through or if they melt or what.
Sometimes the flaps will get stuck in a valve and that will cause a low compression problem. There is at least one thread on KZR with pictures of that.
If a flap gets stuck in an intake valve, that may cause gas to shoot backward out of the carb.
  • bvaleri
01 Jan 2011 14:08
#419628
how can i check if the went in there so i can get them out if they did
  • loudhvx
  • loudhvx's Avatar
01 Jan 2011 21:57
#419684
If it's stuck in a valve, a compression test will show it.
Otherwise, you can take out the plugs and try to look in through the holes.
If you don't find it, don't be too worried as long as your compression is good.
  • TeK9iNe
  • TeK9iNe's Avatar
01 Jan 2011 22:37
#419689
CrAzInEsS! :P
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • bvaleri
03 Jan 2011 11:54
#419870
so the bike is sucking a ton of gas when i have it running and some is coming out the ports where the air box hooks up i have no idea how i can fix this i want to ride this bike already but there always a problem
03 Jan 2011 13:47
#419899
bvaleri wrote:
so the bike is sucking a ton of gas when i have it running and some is coming out the ports where the air box hooks up i have no idea how i can fix this...
Would diagnose as dysfunctional float valves and/or float accompanied by dysfunctional overflow circuit.
Good Fortune! :)
  • bvaleri
03 Jan 2011 14:52
#419912
how would i fix that problem?
  • TeK9iNe
  • TeK9iNe's Avatar
03 Jan 2011 20:25
#419979
Oh boy... first, be VERY patient. These bikes are pretty old, and need some decent maintenece and TLC for thier entire lives. It will never stop. You will get to ride it soon, but you must do everything thoroughly, and correctly the first time.
Search: Carb Cleaning 101 just about anywhere... and begin.
It should only take a few hours - and remember while cleaning the carbs, spray through the pilot jet system, and make sure the spray blows through the passages into the carb bore, the same on all.
Best of luck
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
