1983 kz550 ltd problems
  • bvaleri
  • bvaleri's Avatar Topic Author
28 Dec 2010 08:45
#418882
hi i have an 83 kz550 ltd after a while of work it was ready to be ran it would not start up with out the throttle wide open and once started it would stay until you started to let the throttle go down. it will not idle or run at any low rpm. i have cleaned the carbs i know it needs new float bowl gaskets which i am getting tonight. Could that cause the problem i have? if its not does anybody have other ideas? maybe the carbs need synced i am unsure how to do that and dont relly understand technical terms. if you have any idea please help thanks
  • harm
  • harm's Avatar
  • Tom
Re: 1983 kz550 ltd problems
28 Dec 2010 09:43
#418887
Welcome to KZR!
I would make sure you have good spark and compression on all 4 cylinders. When you cleaned the carbs did you completely disassemble? You may need to bench synch them to get them close. There are a lot of little passage ways in the carbs that must be clear, especially the pilot circuit which controls the lower RPM's. If you don't have one purchase a Factory manual off Ebay, its worth it!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • bvaleri
28 Dec 2010 09:51
#418889
i did clean it all i do not know how to do a bench sync or i would i have strong compression and spark on all cylinders the bke only has 1070 original miles i cleaned it all made sure it i took every jet out could get a clear spray od carb clean going through it and could see through clearly on all jets
  • TexasKZ
  • TexasKZ's Avatar
28 Dec 2010 13:52
#418927
Near the top of the screen is a tab labeled "KZ Information". Put your cursor over it and a small menu will appear.
Choose "Filebase"
Then choose "Non Model Specific"
There you will find several good articles on Mikuni, VM and slide carbs. There are articles on theory, general operation and specific tuning.
Grab some snacks, you may be there a while....
  • bvaleri
28 Dec 2010 18:44
#418982
haha thanks for the tip
  • JR
  • JR's Avatar
28 Dec 2010 20:22
#419025
Is there an idle adjustment thumb screw on those carbs ? Is it possibly something as simple as resetting the idle adjust screw ?
  • bvaleri
28 Dec 2010 22:55
#419064
i really am unsure
  • Motor Head
  • Motor Head's Avatar
29 Dec 2010 05:58 - 29 Dec 2010 06:24
#419087
You really need a service manual for your bike. If you don't have 1 I suggest going to member loudhvx threads and check his signature for a pdf file download. It will show a lot of info, with pictures and how to do the adjustments. When you had the carb's off and apart did you check the intake manifold for air leaks/ crack's? Sounds like if it is not a mechanical linkage problem, then you could have a vacuum leak. Are all the nipples at the manifolds either hooked up properly or plugged off? See why a manual is needed?
Last edit: 29 Dec 2010 06:24 by Motor Head.
  • bvaleri
29 Dec 2010 08:37
#419113
i had a pdf one and it didnt tell me anything useful and then my computer crashed and lost it the intake manifold is fine i plugged all the nipples off after realizing that after the first time i started im still waiting for my new gaskets to see if that helps and i need to find a way to bench sync with out special tools
  • harm
  • harm's Avatar
  • Tom
29 Dec 2010 09:30 - 29 Dec 2010 09:31
#419126
You really need a factory service manual! It explains how to bench sync using 4 pins of the same diameter under each slide and adjusting them from the top side. It is kind of hard to explain this in a thread, a manual wood be the best.
The carbs do have a idle adjusting screw, on the top in the center, can't miss it.
Just to make sure, did you clean 4 main jets AND 4 pilot jets?
Hope this helps,
Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Last edit: 29 Dec 2010 09:31 by harm.
  • bvaleri
29 Dec 2010 09:50
#419131
yes i did clean that and i know that screw is there i just need to know how high up the slides should be or should they be all the way down or what? i live with a mechanic unfortuately he gone for another few days and i need to get it running sooner
  • loudhvx
  • loudhvx's Avatar
30 Dec 2010 01:50
#419260
What model do you actually have? The chain LTD, or shaft LTD? Their carbs are very different.
Here's a diagram for the chain LTD (Kz550C) carbs.
