Kz750 twin key switch problems
- Schmeck
17 Jul 2013 14:18
Hey all, Just wondering about my key switch settings. The bike will only start turned fully to the right but no tailight is seen . In the middle all my lights work but the bike wont start . And ofcourse left does nothing. I bought this switch as a replacement from z1enterprises . Is there something I am missing because I definently need the lights on while at night , thanks
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- MFolks
Re: Kz750 twin key switch problems
17 Jul 2013 15:03
Do you still have the old switch? If so, using a multimeter set on contintuity, you should be able to electrically check the key positions on the old and new switch on the bench. I think you may have the wrong switch, or it's not wired correctly.
- Schmeck
17 Jul 2013 15:06
I bought what was suppose to be a direct replacement or atleast thats what I thought. And I dont know if the switch that was on the bike before is the original because it looks just like the one Ibought from z1
- Schmeck
17 Jul 2013 15:07
The old one I thought was defective but Im not sure it was . Ill put the old one back on and see if it makes a difference .
17 Jul 2013 15:14
What ignition switch did you get? On some of them you may have to do some work to wire them up correctly.
- bountyhunter
17 Jul 2013 17:01 - 17 Jul 2013 17:09The aftermarket switches don't work on the 750 twins. I bought the same one. They plug in but don't make the right connections. I ended up having to unsolder the wires and rewire it to make it work. I have never seen the correct switch for the 750 twin anywhere.Schmeck wrote: Hey all, Just wondering about my key switch settings. The bike will only start turned fully to the right but no tailight is seen . In the middle all my lights work but the bike wont start . And ofcourse left does nothing. I bought this switch as a replacement from z1enterprises . Is there something I am missing because I definently need the lights on while at night , thanks
Last edit: 17 Jul 2013 17:09 by bountyhunter.
- bountyhunter
18 Jul 2013 03:54
The wiring diagram shows how the ignition switch makes connections. I used that to re wire mine.
- Schmeck
18 Jul 2013 09:52
I plugged my old key switch in. Its defective alright , so looks like Im going to be looking at that diagram ,
- Schmeck
18 Jul 2013 09:53
Bountyhunter do you know which wires you switched?
- Schmeck
18 Jul 2013 10:06
The one on the left is old and the one on the right is new. Old one doesnt work other than lights. New one has lights in the middle but wont run unless turned to the right .
Attachment image.jpg not found
- bountyhunter
18 Jul 2013 16:13 - 18 Jul 2013 16:21It's been too many years. I know what I did was use my ohm meter to figure out which contact sets on the switch connected in the two on positions to know what contact sets were available (I think there was more than I needed). Then I soldered the wires in place to connect the right lines.Schmeck wrote: Bountyhunter do you know which wires you switched?
Last edit: 18 Jul 2013 16:21 by bountyhunter.
- bountyhunter
18 Jul 2013 16:20 - 18 Jul 2013 19:18
The power into the ignition switch comes in on the terminal labeled "batt" or battery. You have three feed out lines called TL1, TL2, TL3 and IGN.
In the ON (first) key position, the BATT has to connect to IGN and TL3. In that position, TL1 has to connect to TL2 (not to BATT).
In the second key position (PARK) the BATT has to connect to TL2.
You have to use an ohm meter to figure out what contacts connect to what in each key position. You will probably need to run a wire in from the BATT line to one pad on the switch and jumper it to two other pads. The feed lines to go to the other side of each contact set.
You need to find a contact set for the PARK position to connect BATT and TL2.
Last edit: 18 Jul 2013 19:18 by bountyhunter.
