Original carb´s on a tuned engine???
  • vonF
  • vonF's Avatar Topic Author
01 Nov 2006 15:06
#89153
:S Maybe this is a stupid question?
I have a Z1A engine wich have a bore 1015 and a "Stage 2" tuning(if that make sense)
Is it possible to use the original carbs,Mikuni 28 mm?
And if so,what jets should I use?
  • 77KZ650
  • 77KZ650's Avatar
Re: Original carb´s on a tuned engine???
01 Nov 2006 15:14
#89157
we need a bit more info to give you approx jet sizes, what pistons/cams/pipes are you running ect, not sure what stage 2 is...
Scott
07 MDP Rookie of the Year
  • vonF
01 Nov 2006 15:41
#89167
Sorry,my question was a bit rash.
Just bought the bike as an "objekt".It´s a Rickman CR with a Kawa 900 engine.
I have not been able to track all the previous owners so I don´t know what kind of piston´s and cam´s it is.
All I know is that the bike has a history of racing many years ago.
The guy I bought it from also bought it in pieces and he had never started it.So I think I have some searching to do and then I´ll be back about this.
(Excuse my english,I´m from Sweden):unsure:
  • 77KZ650
  • 77KZ650's Avatar
01 Nov 2006 18:15
#89202
no problem, good luck tracking down your engine info
  • wireman
  • wireman's Avatar
01 Nov 2006 18:59
#89209
excuse my swedish ,im from louisville ne they cant understand me most of the time either!:P the 28s will be fine just need a few more details.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
01 Nov 2006 20:00
#89219
It should run with the 28mm. No big up in displacement. Won't have a "topend" rush but should pull nice thru lower part of rpm range. Need info on intake type, and exhaust type. I think 1 size up on mains for a 4-1 and 1 size up for intake mods. Am a drag racer so I don't think much about bottom end.
  • vonF
02 Nov 2006 09:37
#89319
The intake is modified to around 32mm and the exhaust I don´t have yet but it will be 4-1 Kerker or Vance&Hines for street (if I don´t get my hands on a old Yoshimura system).
The cam lobes(right word?)on an original cam is rather pointed or "narrow" but on those cam´s they are more round or eggshaped so I suppose they are rather "hot".
So if I understand right I should try with 2 up on the main´s?
  • Ron G
  • Ron G's Avatar
03 Nov 2006 16:12
#89587
If you close the throttle slightly during a wide open throttle run and the acceleration picks up then you can go up on the mains.
Ron
  • wireman
  • wireman's Avatar
03 Nov 2006 16:28
#89592
Ron
i say we all need to see a close up of rons red bike:whistle: B) :P
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
03 Nov 2006 19:29
#89606
I say we all need to see a close up of Ron's red bike
Click on the Red bike tab under the small Red bike pic wireman. :whistle:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
