Carb tuning issue
  • xbmxxx
  • xbmxxx's Avatar Topic Author
Carb tuning issue
12 Jul 2012 23:08
#535541
I am helping a friend with a kz740-4 he picked up recently not running. First thing I did was completely disassemble the carbs (not sure what kind they are, they look like these [img]http://http://kzrider.com/archive/images/public/img-1095907948.jpg[/img]
Soaked the bodies and all metal parts in carb dip, re assembled, blew carb clean through all passages, blew out with compressed air, etc. Reassembled and installed, and now it runs. The bike has pods and 2 2-1 exhausts. Installing the factory airbox isn't possible.
The problem is, at idle with the choke on, the LH pipe consistently pops out fireballs, the RH does not. Can ride pretty decent with choke on. Take choke off, its totally different. Wont idle without dying, flat spots and popping while riding, etc.
I have rebuilt both sets of carbs on both my kz's (twins) and never had a problem. Those carbs are also a completely different style. I wasn't aware I was doing it at the time, but when I disassembled them I messed with the needle adjustments, at least that's the best I can figure out what those screws do. Where should those be at? Its (I think) #24 in this picture
Any help with this would be appreciated!
76 KZ750B Twin
  • sham
  • sham's Avatar
Re: Carb tuning issue
15 Jul 2012 10:25
#536041
This might be a really dumb question but have you done the float heights etc yet? I've only worked with a single, but I think I had similar issues to you.
I'm assuming the fireballs you're describing is the result of that carb backfiring, which could mean you're mixture in that one is too lean, your ignition timing is off, spark plug could have issues or valve clearances.
The choke on choke off issues were solved in my instance through getting the jetting ok, and seeing as that's all about the fuel/air ratio it sounds like what you've done with the needle adjustments may be responsible for that. In my case, all my idling issues were in the end related to my pilot jet and its system (I hadn't screwed it on properly).
The manual should state what setting the needle should be at?
Your carbs look way more complicated than mine. Good luck with it.
  • tinlizzie37
  • tinlizzie37's Avatar
15 Jul 2012 14:41
#536093
You are surely running lean. With pods, you'll have to go up to the next pilot jet size. With the stock pipes, I think it will run OK with the stock jets. If not try one up from stock. Bob
Bob KZ 650 E1, En 450
  • xbmxxx
18 Jul 2012 23:53
#536939
couple of corrections to my above post. its actually a kz650-4, not a 750. Also, I went in the manual and found out how to set the needle height and did that. Backfiring issue is solved, but the choke issue is still there. Runs fine with choke on, and I can get it to about half off before it wont idle, I am now leaning towards a vacuum leak.
76 KZ750B Twin
19 Jul 2012 00:13
#536948
Your friend will no doubt need to become more than a little familiar with re-jetting if the bike currently has pods and stock jetting. Ed
  • nitrochristian
  • nitrochristian's Avatar
19 Jul 2012 00:58
#536964
I had same issue, first thing make double and triple sure that the pilot circut is completley free of build up, they make wire cleaners to poke through jets and fully clean them. You getting the fuel you need with choke on and starvin with it off, so at idle when pilot circut is in control your getting less fuel than needed. Most rebuild kits supply new pilot jets because they are hard to clean. Also bench syncing is very helpful it's in manual. Happy ridding
78 KZ650
96 Ford Bronco
  • jsanch08
  • jsanch08's Avatar
22 Jul 2012 22:48
#537747
nitrochristian wrote: they make wire cleaners to poke through jets and fully clean them.
Where might I find these wire cleaners?
22 Jul 2012 23:17
#537755
Click here > www.z1enterprises.com/ItemDetails.aspx?item=KL35-3498
Good Fortune! :)
  • kawasaki mike
  • kawasaki mike's Avatar
  • kawasaki mike
24 Jul 2012 13:43
#538206
As a rule the clip on the needle should be on third grove (middle grove) if your needle has groves. Some only have one, then its a shiming issue for fine tuning.
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
  • baldy110
  • baldy110's Avatar
25 Jul 2012 17:01
#538581
Carbs are still dirty, clean them making sure all the little passages in the badies are clear.
