Mikuni side mount pilot air screws
  • Topper
  • Topper's Avatar Topic Author
31 Mar 2012 20:10
#513252
I seem to remember seeing this before, but I couldn't find it via the search.
Can someone remind me how the side mounted pilot air screws work? Is turning in rich or lean?
This are the Mikuni carbs with the pilot air screw on the side of the carb near the engine.
Thanks!
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Re: Mikuni side mount pilot air screws
31 Mar 2012 20:20
#513256
My understanding of air screws is that turning them out (counter-clockwise) allows more air to enter (leaner) turning them in reduces the air (richer). Ed
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
31 Mar 2012 20:20
#513258
The pilot air screws on the side of the carbs control air flow to the pilot circuit and work as follows:
turn out to lean - by increasing amount of air
turn in to rich-en - by decreasing amount of air
The pilot or fuel screws on the bottom of the carbs control fuel added to the mix and work as follows:
turn in to lean - by decreasing amount of fuel
turn out to rich-en - by increasing amount of fuel
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Topper
31 Mar 2012 21:53
#513278
Thanks guys, that's what I thought. Always nice to get confirmation.
1979 KZ750 Twin
  • Motor Head
  • Motor Head's Avatar
31 Mar 2012 22:29
#513285
Topper wrote: I seem to remember seeing this before, but I couldn't find it via the search.
Thanks!
Topper,
I believe on those Mikuni's you will have a Mixture screw that controls volume of Fuel/ Air mixed already. It should be Less mixture turned in, ie Lean. This is how most CV style carbs are. Screw in front of Vacuum piston, circuit controls volume of mixture made by pilot jet and Air jet.
31 Mar 2012 23:19
#513296
Good Fortune! :)
  • Topper
31 Mar 2012 23:43 - 31 Mar 2012 23:47
#513299
Motor Head wrote: I believe on those Mikuni's you will have a Mixture screw that controls volume of Fuel/ Air mixed already. It should be Less mixture turned in, ie Lean. This is how most CV style carbs are.
Thanks Moto Head.I don't think these are like most CV carbs. The screw is on the side of the carb and close to the engine.
I think 650Ed and gd4now are right here.
1979 KZ750 Twin
Last edit: 31 Mar 2012 23:47 by Topper.
  • Motor Head
01 Apr 2012 10:29
#513343
The Air Screws are usually behind the Slide, near the Air Jet, at the back of the carb. I don't have a circuit diagram for your carbs, but would think being between motor and slide, that they are mixture volume screws.
01 Apr 2012 11:02
#513354
Topper wrote: ...Can someone remind me how the side mounted pilot air screws work? Is turning in rich or lean? This are the Mikuni carbs with the pilot air screw on the side of the carb near the engine. Thanks!
:unsure: Referring to oem carbs on one of the two models shown in sig?
1979 KZ750 Twin? 1988 KZ305 LTD? Some other carb?
The following might possibly be helpful:
www.wgcarbs.com/index.php?option=com_con...view&id=27&Itemid=27
Good Fortune! :)
  • gd4now
  • gd4now's Avatar
01 Apr 2012 12:37
#513372
OK I had not paid attention to the models of bikes you have noted in your sig. My response was related more to the mechanical slide carbs (VM style) and not the diaphragm ones (CV or BS style) So which bike are the carbs in question from. The 750 or the 305. If it is the 750 then they should be BS38s for the 1979 750. I am not sure just what was used on the 305 but would think they were either BS34s or 32s.
IIRC there is a side pilot air screw on the BS38s, but on the BS34s and 32s the pilot adjustment screw is on the top of these carbs and does work differently than the ones on the side do.
1977 KZ650 B1
  • Topper
01 Apr 2012 15:13
#513395
This is for the '79 750 twin. I actually need to remove the 305 from my sig.
I was all excited when the first two responses confirmed my recollection, but now it sounds like there's still some doubt.
1979 KZ750 Twin
  • gd4now
  • gd4now's Avatar
01 Apr 2012 15:26 - 01 Apr 2012 16:40
#513396
OK so it is the BS38s and for them I think that the mixture screw works as follows
Turn in to lean
Turn out to richen
You might want to check out this link www.amckayltd.com/carbguide.pdf though it is for the Yamaha 650s some of them use the BS38s and there is some good info in the document.
1977 KZ650 B1
Last edit: 01 Apr 2012 16:40 by gd4now.
