kz550 vaccum operated petcock aftermarket tank
- jason289
28 Feb 2012 04:58
I'm new to kzr and i apologize in advance for dumb questions. I'm building a hardtail kz550 bobber and i have an issue with the tank i intend to run.It's an aftermarket tank for harleys and has the harley screw in petcock inlet.I have it hooked up and my carbs have been leaking fuel.My question is,is there an aftermarket vaccuum operated petcock that will function like the original? Is it the float valves? or am i boned?I don't have the original tank and i would rather run something else.
- loudhvx
Re: kz550 vaccum operated petcock aftermarket tank
28 Feb 2012 05:14
If the carbs overflow for a brief period then stop, then that means the floats are set wrong or the float valves are leaking, or even possibly that there is a cracked overflow pipe inside the bowl.
If the carbs keep leaking for a long time, then the petcock is also bad in addition to the carbs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: jason289
Last edit: 19 Feb 2013 14:00 by martin_csr.
- jason289
28 Feb 2012 20:44
Very good advice guys,thank you.I did clean out the tank the best i could and used seafoam in the fuel beforehand.This is my first complete basketcase project.I knew it was going to be a challenge.The carbs need to be gone thru and adjusted who knows how long it's been sitting neglected.
- loudhvx
28 Feb 2012 22:02
Forgot to mention, you can find links to a lot of 550 info in my signature.
1981 KZ550 D1 gpz.
Other links.
Other links.
