BS34 1985 GPz 750 Mildly ported Need Jetting Ideas
- H-60MGuy
- 1985 GPz 750 Streetfighter
26 Feb 2012 00:32 - 29 Feb 2012 02:25
Hello! First post here for me, so here goes. I have a 1985 GPz/ZX750 A3 that came with a set of BS34's. Top end of the engine has been torn down, inspected, honed, new OEM rings, stock pistons. Thsi is where it gets crafty: The head has been ported for street use, combustion chambers blended and semi-mirror finished, .006 removed from head surface. Stock valves, stock GPz cams. I destroyed the original airbox, but have another one in the mail. I need reccomendations on jetting for these carburetors. I do not want to fire this thing up and wash my cylinders down, and I do not want to burn it down from being too lean. Current jetting is 110/37.5.
"See, what had happened was.........."
Last edit: 29 Feb 2012 02:25 by H-60MGuy. Reason: update
- H-60MGuy
Re: BS34 1985 GPz 750 Mildly ported Need Jetting Ideas
29 Feb 2012 02:28
My biggest concern is break-in. Am I safe to break in the engine with current jetting?
- mtkawboy
29 Feb 2012 21:15
Thats the same jetting I run on my 82 GPZ750 that has ported heads on it from the factory & an old 4-1 RC header on it & 16,000 miles. Whether the later ones have the same heads I dont know but I do know they {later ones} have slightly hotter cams in it. It may not be spot on but I sure wouldnt worry about it breaking it in with that jetting. maybe uncover the mixture screws abd back them out a half turn is all. My opinion only, others may vary
- H-60MGuy
01 Mar 2012 04:41
Thanks! I have uncovered the mixture screws, I will work with them and break it in, then see what the plugs have to tell. Just a heads up to anyone ordering from Dynoman.........Vesrah gasket kits are being ordered on a demand basis, they had to order mine from the factory. Not a big deal as i have more time to clean and prepare, just mildly frustrating!
- gengomerpyle
01 Mar 2012 16:15
im running 118 mains and 37.5 pilots with a 4in1 kerker with stock air box
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- H-60MGuy
01 Mar 2012 21:32
Thanks! I am also running the Kerker 4 into 1. Did you work your way up to the 118's from 110's?
- gengomerpyle
02 Mar 2012 17:06
no they were there when i bought the bike. it has a stage1 dynojet kit in them and thats is what they say to use with a after market pipe with a stock air box. i havent had any problems with the jet size.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
The following user(s) said Thank You: H-60MGuy
- H-60MGuy
02 Mar 2012 19:00
I'll give the 118's a try once I'm confident the cylinders are sealed. Unfortunately I will not know how well my build is until tomorrow when I assemble the top end. Apparently my 24 hr shift is more important than the bike to my employer (US Army).
PS: That is a CLEAN bike you have! I like!
- gengomerpyle
02 Mar 2012 19:31
thanks, i just had my carbs rebuilt a few weeks ago and they have been working great. they worked great when i bought my bike but i started to have some problems a few months ago. the old owner had put the wrong type of pilot jets in the carbs so when i had them rebuilt the builder rick replaced them for the correct ones.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- mtkawboy
02 Mar 2012 20:06
www.jockeyjournal.com/forum/showthread.php?t=64769
Once again Ill post this. A 118 Dynojet jet = a Mikuni 110.6. In other words you both have the same jetting. All you need is the adjustable needle and mine runs just fine with the factory needle in it
- H-60MGuy
02 Mar 2012 23:47
Thanks MtKaw! Interesting info.....did not know that.
- gengomerpyle
03 Mar 2012 11:15
same here, i didnt know that neither
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
