Quick jetting question for Mikuni 29s
- 2wheeltom77
25 Feb 2012 13:11 - 25 Feb 2012 13:12
I've done a lot of reading on here and am thinking my carbs were overjetted. I rode this bike for just a few minutes after I bought it and then tore it down for the build. It had been sitting for a long time but ran ok and had good power. The engine looked like a 40k engine, but the plugs were completely carboned up. I just got into the carbs yesterday and discovered they are VM29s, but have 127.5 main jets. Pilots appear to be 20. I'll be running pods and a 4 to 1 pipe. I believe the engine is stock. Cold compression was 107 to 120 FYI. Location is KC, so not high elevation. Any thoughts?
BTW, it's a 79 KZ1000.
1979 KZ1000 one off
1982 Honda CX500 (sold)
2008 FXSTC
2008 FXSTC
Last edit: 25 Feb 2012 13:12 by 2wheeltom77. Reason: added info
- mtkawboy
Re: Quick jetting question for Mikuni 29s
25 Feb 2012 18:43 - 25 Feb 2012 18:44
Way rich on the mains, mine are at 120, pilots are Ok at 20, I have the needle clips written down some where but cant find them. I believe its one clip down from the center {needle raised 1 clip} Air screw is out about 1/8 turn. That will get you closer then you are anyway but also synch the carbs
Last edit: 25 Feb 2012 18:44 by mtkawboy.
- 2wheeltom77
27 Feb 2012 20:30
Thanks for the reply. I checked one needle and the clip was in the middle. On further inspection, those 127.5 jets weren't all identical either. No clue where the previous owner scrounged them up. I went ahead and ordered 120 mains and new 20 pilots.
1979 KZ1000 one off
2008 FXSTC
2008 FXSTC
- testarossa
28 Feb 2012 10:52mtkawboy wrote: Way rich on the mains, mine are at 120, pilots are Ok at 20, I have the needle clips written down some where but cant find them. I believe its one clip down from the center {needle raised 1 clip} Air screw is out about 1/8 turn. That will get you closer then you are anyway but also synch the carbs
+1 on these recommendations. You should be close with these settings.
However, those compression numbers are not ideal. Have you checked your valve clearances recently? Does the bike consume very much oil?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- 2wheeltom77
28 Feb 2012 21:57testarossa wrote: However, those compression numbers are not ideal. Have you checked your valve clearances recently? Does the bike consume very much oil?
I just bought the bike as a project. The compression test was done cold. I did reshim the valves when I had the motor apart. A couple had basically no clearance. I'll hopefully have it together by the end of May. If it runs alright I'll do a good compression test warm. It has 40k on the motor and it is ready for a refresh. Gonna ride it this summer and hopefully rebuild the motor next winter.
1979 KZ1000 one off
2008 FXSTC
2008 FXSTC
