What carbs are these?
  • DoubleDub
  • DoubleDub's Avatar
Re: What carbs are these?
22 Feb 2012 23:31
#505782
Likely Mikuni VM28's then.
  • Rockabillybobber
  • Rockabillybobber's Avatar Topic Author
22 Feb 2012 23:33
#505783
but thats with my caveman tape rule! need to get a mic for a proper measurment
  • Rockabillybobber
22 Feb 2012 23:34
#505785
ok maybe you could help me out with figuring out what size jetting i need?
Thanks for the help!
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
22 Feb 2012 23:34
#505786
wrong drain plug for 28's
  • DoubleDub
22 Feb 2012 23:38
#505790
Yeah, they look like the 26's.
  • Rockabillybobber
22 Feb 2012 23:39
#505792
float bowl drain plug? could it just be the wrong plug in 28's? not sure if thats even possible, but im new to these carbs so who knows
  • Rockabillybobber
22 Feb 2012 23:42
#505793
the inside diameter is 28mm, does the 26mm's also have the same?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
22 Feb 2012 23:43 - 22 Feb 2012 23:44
#505794
The later 28s had the regular bowl without the jet access.
In the picture with the choke lever,look under the screw and on the flange near where it fits into the rubber boots there will be some numbers. Same on other side.
The best way to find the jets size is to remove the bowls and look .
Last edit: 22 Feb 2012 23:44 by roy-b-boy-b.
The following user(s) said Thank You: BlackZ1R
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
22 Feb 2012 23:47 - 22 Feb 2012 23:50
#505796
Glad you got photobucket up and going. Those are 28s. Most 26s that I have seen had the air screw sealed.
We need to more about your engine combination to recommend jetting.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Last edit: 22 Feb 2012 23:50 by BlackZ1R.
  • Rockabillybobber
22 Feb 2012 23:52
#505799
ok i believe the choke lever side says 110 with a 9 under it, and the opposite side says PO with an 11 under it?
  • Rockabillybobber
22 Feb 2012 23:56
#505801
as far as I know stock internals(supposed 20yr barn find), 4-1 header into unknown muffler, pods that havnt been run yet. Just did a head gasket on it and everything in the heads looked clean an real low wear.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
22 Feb 2012 23:57
#505802
I think they look more like 28s than 26s - the single fuel inlet and the idle adjustment on the bottom make me think MII.
Do see if you can get the ID mark that Roy spoke of - just below the choke lever. With the ID we may be able to ID the carbs for sure.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
