Decel pop ...STILL
- filztoy
Decel pop ...STILL
21 Feb 2012 20:01 - 21 Feb 2012 20:17
Can anyone tell me what carbs I have? 1980 kz1000 B4, I've seen pics of 28's and 29's and have not seen my carbs,no accel pump,17mm drain plug,I'm thinking that I'm still running lean and want to change the pilots,currently running 17.5's
Last edit: 21 Feb 2012 20:17 by filztoy. Reason: addiontal info
- moneypit
Re: Decel pop ...STILL
21 Feb 2012 20:56
Those look like 29s to me.
Here are some pics for comparison
Intake side
Right side while on bike
As for the pilots I cant say ?
Attachment 29jet.jpg not found
Intake side
Attachment 29mm-Smoothbore-carbs-side_2012-02-21.jpg not found
2-76 kz900
St Paul MN
St Paul MN
21 Feb 2012 21:44 - 21 Feb 2012 21:53Regarding decel pop, before changing to larger pilot jets, would first try slightly enriching the pilot circuits by turning each pilot air screw in clockwise say 1/4~1/2 turn, and test run.
Also, decel pop may result from a too low fuel level or an imperfectly clean pilot circuit or incorrect sync or air leak.
Last edit: 21 Feb 2012 21:53 by Patton.
- bountyhunter
21 Feb 2012 22:48
Make sure fuel levels are right, check with clear tube.
- Powerstroke_fan
22 Feb 2012 10:05
stupid question, but could it be the emmission ports causing to pop on decel?? only reason i suggest it is mine did the same till i plugged them.
1977 KZ 1000 work in progress
- Polar_Bus
22 Feb 2012 11:54
If you don't have an intake or exhaust air leak, the only other cause for decell pop is excessively lean pilot jets.
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- filztoy
22 Feb 2012 12:17
Thanks Guys I pretty much covered the air leaks,new exhaust gaskets and new carb holders,float level @ 3mm,emissions plugged,when I pull the choke on just a hair it doesn't pop,so I'm thinking of going up to 20 pilot I'm already runnin a 17.5.and thanks Patton and moneypit for the pics they are a big help.
22 Feb 2012 12:32 - 22 Feb 2012 12:36Seem to recall others having reported unplugged ports caused popping exhaust.Powerstroke_fan wrote: stupid question, but could it be the emmission ports causing to pop on decel?? only reason i suggest it is mine did the same till i plugged them.
Attachment airinjectepavalvecover.jpg not found
Last edit: 22 Feb 2012 12:36 by Patton.
- filztoy
22 Feb 2012 19:06
Not a stupid question at all,after your post I gotta thinkin,the previous owner had connected both hoses with a T and to a small pod filter,I wouldn't have thought about it, BUT I pulled the filter and put a 3/8 bolt and clamp!Whatta ya know no more DECEL POP.I'm gonna pull the tank tomorrow and replace the hose with just one piece.Thanks a bunch this has been drivin me crazy!And Thanks Patton for the emission pics.
- Powerstroke_fan
22 Feb 2012 20:24 - 22 Feb 2012 20:26
glad to help. what i did is pull the valve cover off and go buy some plugs and tap and plug the emission ports in the head.i used to have a one piece hose and it still poped.I had to plug them.
Last edit: 22 Feb 2012 20:26 by Powerstroke_fan.
- filztoy
24 Feb 2012 17:03Attachment KZ1980Emissions001.JPG not found
Hey Guys I've seen everything now, I thought that I had been over every inch of this bike,come to find out I guess I haven't, check out this contraption that the previous owner did!2 pieces of 5/8 hose to a 3/8 tee with 3/8 fuel line going into the 5/8 hoses and a small filter pod. I replaced the hose with 1 piece of 5/8 heater hose and ALL the decel pop has went away.If any of you guys are @ the Vintage Japanese show in Jefferson PA in August I'll buy ya lunch!Thanks again
- Powerstroke_fan
24 Feb 2012 17:22
are we talking steaks or bologna? lol jk glad you got it straightened out.
