Help me decide
- 2wheeladdict
Re: Help me decide
21 Feb 2012 18:45
A complete kz 1000 or 900 engine just sold on ebay for 300.00 and came with a set of 29mm smoothbores. type "spare kz1000 engine" into search and check completed listing option on the left side and check pics. I think it ended on or about the 12th of Feb. I didn't have the spare $$$$ to bid. shipping would have been from washington state. But a great deal..
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
84 CR60r
- T_Dub
Re: Help me decide
21 Feb 2012 20:02DoubleDub wrote: I've never fully understood why larger CV type carbs are used where smaller manual slide type carbs are used.
Yeah its a little strange really.
Thats an awesome deal on that engine. I'd like to be the guy who got that!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- T_Dub
Re: Help me decide
21 Feb 2012 20:32
Orrrr, I could get a dynojet kit for my BS34's. I may go this route.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Jeff.Saunders
Re: Help me decide
21 Feb 2012 22:00
26mm or 28mm carbs from a KZ900/KZ1000 would work very well. 26's are a little small for the 900/1000 engines, but 810cc is 10% smaller - and would run very well - you'd have good throttle response through the lower mid-range - something you'd lose with bigger carbs. VM29's or CR29's would be a great choice - if money is no object. Anything larger is really too much carb on the street. Racing I would probably change that answer...
The following user(s) said Thank You: BlackZ1R
- T_Dub
Re: Help me decide
21 Feb 2012 22:21
Jeff, I actually had a question about VM26/28's. I'm sure you have the answer. How can you tell the difference? Which came on what?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- DFIGPZ
Re: Help me decide
21 Feb 2012 22:49
I would use a set of 28mm carbs from 79/80 kz1000
1984 750 Turbo
- T_Dub
Re: Help me decide
21 Feb 2012 22:52
Do all the 79/80's have 28mm carbs? Is there an easy way to tell the difference?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- DoubleDub
Re: Help me decide
21 Feb 2012 23:39 - 21 Feb 2012 23:41
From what I've been able to gather:
73-75 Z1 had 28's w/out accel pump.
76-78 Kz900/1000 had 26's, some with, some w/out accel pump.
79-80 Kz1000 had 28's w/accel pump.
The 26 and 28mm carbs with accel pumps are very similar. The 29's had an extra hole in the intake bell.
please correct me if I'm wrong.
Last edit: 21 Feb 2012 23:41 by DoubleDub.
- T_Dub
Re: Help me decide
21 Feb 2012 23:52
You guys make good points. New carbs would be some cool tho.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
Re: Help me decide
21 Feb 2012 23:53
Some good info about carb i.d. may be found at Z1E.
www.z1enterprises.com/reference/z1-carb-guide.aspx
- Jeff.Saunders
Re: Help me decide
21 Feb 2012 23:56
the easiest way to tell - measure the ID on the engine side - 26mm will measure around 26.7mm, 28mm carbs measure around 28.8mm
Z1's used an earlier VM28 carb - easily distinguished by the angular top held on with just 2 screws.
KZ900 and most of the 77-78 KZ1000's used 26mm carbs - only the Z1R used 28mm carbs. None of these used accelerator pumps - and all had adjustable needles with 5 clip settings.
It gets a little more confusing in 79/80. The A model, the Z1R and the shaft bikes all used 28mm carbs. The 79 LTD used 26mm carbs - I'm not 100% sure on the 80 LTD or the police bikes.
The following user(s) said Thank You: DoubleDub
- T_Dub
Re: Help me decide
21 Feb 2012 23:57
Yeah I knew about that page, but he doesn't talk about the KZ1000 VM28's.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
