Carb kit jets
- bluej58
Carb kit jets
17 Feb 2012 19:37
I've started swapping out all the little parts that the kits came with and found that the main jets they gave me are 105 and 107.5
I have the stock 102.5 in there now :pinch:
I'm running my old 2 into 1 Jardines and the existing jets worked well IMO
I wondering if the 105's would be OK or should I just stick with the old 102.5's ?
Is any one running those old mufflers if so what jets you using.
JD
JD
78 KZ1000 A2A
- bluej58
Re: Carb kit jets
18 Feb 2012 03:08
Stupid question, I'm just going to order the right jets and have a nice stock pile if I decide to build another bike :woohoo:
78 KZ1000 A2A
- TomW
- Keep the blue side up.
Re: Carb kit jets
18 Feb 2012 03:14I ran into the same situation when I rebuilt the 26mm carbs on my '78 KZ1000 LTD.bluej58 wrote: I've started swapping out all the little parts that the kits came with and found that the main jets they gave me are 105 and 107.5
JD
I was advised that the '78's were jetted lean from the factory and the 105s would work fine. They did. I couldn't tell any difference. I subsequently switched back to the 102'5 jets when I was out west at high altitudes. Made no noticeable difference.
If your 102.5's are in good shape, use them. If you switch to the 105, you may lose a tad bit of fuel economy and the motor may like the extra fuel at high speeds. The mains really only come into play at 3/4 to full throttle. At legal cruise speeds the fuel delivery is controlled by the needle and pilot jets. Your pilot jets are probably 15's
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- TomW
Re: Carb kit jets
18 Feb 2012 03:22You can go that way also. The jets are only 4 or 5 bucks each. Just sayin the 105's will be fine in an otherwise stock motor. BTW, mine is all stock 4 into 2 pipes, cams, carbs and air box..bluej58 wrote: Stupid question, I'm just going to order the right jets and have a nice stock pile if I decide to build another bike :woohoo:
- bluej58
Re: Carb kit jets
18 Feb 2012 12:33
Thanks Tom, yes the new and old pilot jets are 15's .
I really have no ambition to go much faster that 80 mph any more, tickets are too expensive.
And I definitely have no desire to go out looking for a race so I think I'll just clean them up and reuse em .
The 105's will be there if I change my mind.
Plus I'm hoping to get 45 mpg like back in the olden days.
No flash ,no loud pipes , just an old f--k on an old bike putting down the road....
For now anyways :woohoo:
JD
JD
78 KZ1000 A2A
- TomW
Re: Carb kit jets
JD
Good luck with 45 mpg. Maybe at 35 mph.
You just described me. Old fart on an old bike, not pretty,but pretty dependable. The bike that is.
