thinking about pods
- agreendrop
Re: thinking about pods
15 Feb 2012 13:40
Thank you to all you took the time to respond to my under-researched question. Looks like I'll probably put the pods on hold until I have done enough research that I understand the entire process.
Just for kicks, I might stick a set on and see how it runs as is. It can't hurt to try, right?
Andy
1982 KZ750 CSR
1982 KZ750 CSR
15 Feb 2012 13:49agreendrop wrote: Thank you to all you took the time to respond to my under-researched question. Looks like I'll probably put the pods on hold until I have done enough research that I understand the entire process.
Right.
Will likely encounter the typical difficulty in achieving perfect performance throughout the entire throttle range, especially with CV style carbs.
For example, slightly better WOT performance might be achievable with pods, but at the expense of less stellar mid and low range where most riders are most of the time.
- ready2ryde1985
- got to love these kzs
15 Feb 2012 13:58 - 15 Feb 2012 14:01
I like my pods But I didnt get a choice the stock box was lost long ago...
I would heid the warnings def need to re jet to make the bike run right with all the extra air.
Lean bike go boom ......
K&N are good but def $$$$
Still any time the bike is exposed to changes on the exaust or intake it needs to be jetted just my .02
The main thing to remember is lean bike go boom !!!!!
Attachment RC-0984.jpg not found
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
Last edit: 15 Feb 2012 14:01 by ready2ryde1985. Reason: had to find a dif pic of the k and n
15 Feb 2012 14:36agreendrop wrote: Thank you to all you took the time to respond to my under-researched question. Looks like I'll probably put the pods on hold until I have done enough research that I understand the entire process.
I wouldn't bet my engine on it. As ready2ryde1985 stated it will run lean. Lean = hot.
- LarryC
15 Feb 2012 14:49 - 15 Feb 2012 14:56
IMO, there can be no greater waste of time & money that f'kn around with pod filters on a KZ with a stock motor that originally had CV carburetors. That would be every J motor bike that ever rolled off the production line...save the fuel injected models.
Either that or you break down a buy a good jet kit. Without that, the performance gains you get will not be worth the time and effort involved.
You want a fuss free, smooth running, good accelerating stock CSR.... leave the carburetors alone. Put a new air filter in the stock box. Leave the OEM CDI alone. Spend your money on good tires, suspension improvements, chain & sprockets. Go through your wiring harness and clean all the connectors. Change the ancient brake fluid. Check and replace if needed, the brake pads, battery, etc.
In short...focus on the things that make the bike trouble free, comfortable and safe to ride.
Larry C.
Last edit: 15 Feb 2012 14:56 by LarryC.
The following user(s) said Thank You: BlackZ1R
- roy-b-boy-b
15 Feb 2012 15:16
What he said. Times 10
LarryC wrote: IMO, there can be no greater waste of time & money that f'kn around with pod filters on a KZ with a stock motor that originally had CV carburetors. That would be every J motor bike that ever rolled off the production line...save the fuel injected models.
- bountyhunter
15 Feb 2012 16:57Depends. It's going to run leaner. Depending how much leaner you could get blue pipes or a hole in a piston.agreendrop wrote: Thank you to all you took the time to respond to my under-researched question. Looks like I'll probably put the pods on hold until I have done enough research that I understand the entire process.
- ready2ryde1985
15 Feb 2012 17:01
WoW
UM
I have no where near the experience these cats do and I have been here a while they know their $hit.
In short...focus on the things that make the bike trouble free.
Good words ...
UM
Good words ...
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- TeK9iNe
- What did you do!?!
15 Feb 2012 21:31650ed wrote: no
:woohoo: :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
15 Feb 2012 21:38LarryC wrote: IMO, there can be no greater waste of time & money that f'kn around with pod filters on a KZ with a stock motor that originally had CV carburetors. That would be every J motor bike that ever rolled off the production line...save the fuel injected models.
Absolutely, precisely, bang-on! :laugh:
I had Pods on my 79 with slides, 81 CSR is airbox all the way!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- agreendrop
15 Feb 2012 23:35
It's good to hear all of your thoughts on the topic.
Great advice LarryC! It's easy to get carried away with fun things you want to do to make it look or sound cool, but in the end it's all about being able to ride it.
Andy
1982 KZ750 CSR
1982 KZ750 CSR
- BlackZ1R
- Kawasaki in my blood
21 Feb 2012 12:49
Good answer to someone that knows nothing about how carburetors operate.
FWIW, I run pods on several Kawis with CVs and they run flawless with the proper jet kit installed. Unless I'm missing something special about the CVs on J models, it has to be the fact that the owners aren't installing the proper jet kits to run pods on their bikes.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
