wet float level for 900
- terry s
10 Feb 2012 19:25
Has anybody rigged up a way to do the hose float heighth test for a 74 900 kaw? I have the one with the big plug in the middle you have to put a 17mm wrench on. They are real fine threads.
- dshelly
Re: wet float level for 900
10 Feb 2012 19:34
Which carbs do you have? If it's the 28's I might be able to hook you up.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- terry s
10 Feb 2012 19:41
I think it is the 28. How can I tell for sure?
10 Feb 2012 21:16 - 10 Feb 2012 21:17
If speaking of the clear tube test, would probably be same as on smoothbores.
A short length of whatever size rubber fuel line (maybe 3/8") that fits snugly inside the hole, with the clear line beginning from inside the larger section.
I use a cone shaped rubber grommet held inside the hole.
Slight leakage won't invalidate the test.
Last edit: 10 Feb 2012 21:17 by Patton.
10 Feb 2012 21:29 - 10 Feb 2012 21:30
Z1E lists the 17mm plug screw for 29 smoothbore et al, but doesn't mention the early Z1 carbs. So guessing threads are different.
17mm plug for smoothbores
If a spare plug is available, it could be drilled for a barb insert to fit the clear tube.
Last edit: 10 Feb 2012 21:30 by Patton.
- terry s
10 Feb 2012 21:47
The 17 mm I was talking about is the wrench size to screw the plug out. That hole in the bowl is about 5/8''. I will see if I can find a tapered rubber. The only problem is that jet is right there at the hole. It would be great if I could find a spare plug. Then like you said drill and tape a fitting in it. Are there anybody with a spare plug out there?
- dshelly
10 Feb 2012 22:19
Terry, check your PM's
dshelly
dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
