carb swap
- nobody
carb swap
09 Feb 2012 22:21
hi first off i did do search no luck if i missed something tell me pleas i dont want to make any body mad.i like this site a lot . my ? is will a set of carbs steel tops kz1000 fit on an 1982 kz1100 d ?
- baldy110
- nobody
Re: carb swap
09 Feb 2012 22:45
bs ? 34 yes look a lot alike but center two carbs are to close together :huh: :huh:
- DiamondSkyBlue1000
Re: carb swap
09 Feb 2012 23:08
No one should get mad at you for asking an honest question.
Need to know more about your carbs.
My 77 has BS34 carbs that came off of a later year model kz so, if you have a set of carbs that came off of an earlier kz {like a set of VM26) then they should fit. You will need the proper size boots and the cable(s) will probably be different. Most likely your later model bike will have a vacuum operated petcock and if the carbs are older they may not have a port for that.
- nobody
Re: carb swap
10 Feb 2012 02:41
thank you i do have port for pet cock now this boot thing ? what do i need to do ? will have pod filters jetting next ?? lol more on mounting to engine what boots do i need ?any and all help needed and appreciated thanks
- roy-b-boy-b
Re: carb swap
10 Feb 2012 09:26 - 10 Feb 2012 09:27
If you have both sets of carbs,remove the set that is on the bike and install the ones in question.
The CV type carbs have square tops and the earlier VM series carbs have oblong tops.
Your bike should have the larger boots already.
The boots are the rubber pieces the carbs fit it.
Some of the CV carbs had aluminum tops and some had steel tops. Some have plastic. Roy
Last edit: 10 Feb 2012 09:27 by roy-b-boy-b.
- ready2ryde1985
- got to love these kzs
Re: carb swap
10 Feb 2012 10:54
Dont mean to hijak this thred!
Roy where can I get a set of the aluminum tops for my set of bs34s is there a site that carrys them or do I need to find a set of 34s with them ????
Thanks !
and if you reach a snag and need a hand or someone to talk to about your carb issue Widegordge carbs the man there is a saint he has talked me threw lots of carb issues that most wouldnt waste a min on just my .02.
Thanks !
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- roy-b-boy-b
Re: carb swap
10 Feb 2012 11:33
P.M. sent on the tops. Roy
- nobody
Re: carb swap
10 Feb 2012 12:28 - 10 Feb 2012 17:00
hi and thanks
but and maybe i missed it, (will get pics today) the two outer carbs are real close to lining up but center two are off not a lot but dont line up with intakes maybe there not off of kz1000 i dont know let me get pics :sick:
:huh: well hear are some pics #1? what kind of carbs are the silver ones ? ::#2? what did the kz1100d come with stock ? the black ones , they are not what i want to start with :#3? and is there a intake that will make it work ? i see differences and i can make them work but will they even feed this beast ?
Attachment kz1100carbs001.jpg not found
Attachment kz1100carbs007.jpg not found
Attachment kz1100carbs003.jpg not found
Attachment kz1100carbs009.jpg not found
Last edit: 10 Feb 2012 17:00 by nobody.
- nobody
Re: carb swap
10 Feb 2012 23:34
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :S
- BlackZ1R
- Kawasaki in my blood
Re: carb swap
11 Feb 2012 12:32
FWIW, you're posts are somewhat confusing.
Learn to use punctuation and sentence structure and you'll get more concise replies to questions we can more clearly understand.
Kapeesh?
I take it you have a J model KZ1000 that you want to install carbs off of an 1100 on to??
From the carb pictures, I don't know what you have , but they don't look like J model carbs to me. I may be wrong.
What is wrong with the original carbs that came on the bike, other than you have them in 200 pieces now? :silly:
Not sure why you are taking your carbs that far down to work on them. It isn't necessary to completely dissasemble them to clean the bodies and jets.
The carbs off of most any J model should work on your bike. Picking up a full unmolested set should be fairly easy. Early model 26s or 28s will work with the proper manifolds and cables.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Re: carb swap
11 Feb 2012 14:07
Okay, nobody, slow down, take a breath, relax.
First things first:
All of your photos are labeled as kz1100 carbs.
Yet, you mention that they are from two different bikes. What we are trying to determine is if the carbs in the photos are from two different bikes, the black ones are the ones you want to use and the silver ones are not? Or are we wrong here?
Please answer that first.
If they are indeed from two different bikes and yet one set is in much better shape than the others and that is why you want to use them -then- you can probably put the desired carbs on the other set's rails. But clarify what you want to do first.
One step at a time, friend.
First things first:
The following user(s) said Thank You: BlackZ1R
