main jet and holder
- kz what
main jet and holder
09 Feb 2012 21:29
does anyone know where i can buy a 4 105 main jet and holder for my kz 650.Found some on ebay but they sold quick
- moneypit
Re: main jet and holder
09 Feb 2012 22:12
Try Z1 enterprises Pick you year then go to carb and pick them out
www.z1enterprises.com/catalog.aspx?pid=KZ650
2-76 kz900
St Paul MN
St Paul MN
- kz what
10 Feb 2012 07:54
i tried to find them there but no luck.They dont look like the regular main jet they look like a main jet with a tube attached to it with holes in it.do you know if i can change them for the regular slyle jet?
- DoubleDub
- gd4now
- Denco where did you go?
10 Feb 2012 16:46 - 10 Feb 2012 22:35
It would help to know the year and model of the 650. But if I am correct the part you are calling a main jet with a tube attached is actually 2 different parts. The main jet (the 105 you are looking for) screws into what is called a bleed pipe, which screws into the carb body just below the needle jet, which is pressed into the carb body.
I have attached a parts diagram from a B1/B2 which shows the parts of the vm24ss carbs used on those years/models. Depending upon your bikes year and model the part#s may be different, but the parts are very much the same.
The main jet is # 28 and the bleed pipe is #26 and the needle jet is #25.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 10 Feb 2012 22:35 by gd4now.
