How can you tell what carbs you have?
  • badrhino
  • badrhino's Avatar Topic Author
24 Nov 2011 00:23
#489916
So I bought a set of carbs off fleebay and I assume they are 34mm. I measured the boot side and got 33.7mm How can you go about telling for sure? I really can't find any numbers or anything on the carbs.
The guy I bought them from said they were in working condition and came off of a running bike (1980 Kz1000)and might need a light cleaning. I took them apart and the floats were mostly stuck and the slides did not move until I freed them up. There was a gummy fuel residue all over them and he must not of completely drained before shipping them as there was leakage all of the packaging. Another bad feebayer.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • Motor Head
  • Motor Head's Avatar
Re: How can you tell what carbs you have?
24 Nov 2011 00:26
#489917
Picture? Manual slide or Diaphragm?
  • badrhino
24 Nov 2011 00:34
#489918
Diaphram
Franken Z!
  • Motor Head
24 Nov 2011 00:37
#489919
Not the best picture, but sure looks like Mikuni BS34"s. Good Carb for a More or less stock street engine. Parts are pretty easy to get, plenty of jets etc. With the Diaphragm slide, it needs a good steady signal through the Whole carb, so an Airbox is Best. Although some do tune them to run with pod's.
  • badrhino
24 Nov 2011 00:47
#489922
I was wanting to run pods and I expected the carbs to be in better shape then they are. I have a set of 29mm smoothbores that came on the bike but I don't know what all if anything that they will need to work properly. Just wondering what would work best and the cheapest. I know the 29's look awesome on there with the pods.
Franken Z!
  • Motor Head
24 Nov 2011 00:57
#489929
You want to Run those Smooth Bores. Don't put the money into the BS34's for your build. Shouldn't be to difficult to fix up the Smooth Bores and that will be money well spent. Worst they might have a cracked jet block. If so send a PM to Testorossa. He has fixed a few, I believe.
  • badrhino
24 Nov 2011 01:02
#489930
Ok, I figured that much. Plus those 29's just look the shit. Well I guess I'll keep the 34's as a backup or clean them up and resell them.
My engine is not stock as it is a J motor with 1100 heads with a Vance And Hines 4 into 1. I have no clue what else has been done to it. Will the 29's be better than the 34's for this application and for most applications other than stock?
Franken Z!
  • Motor Head
24 Nov 2011 01:07
#489931
Most any of th KZR guys would trade a testicle for those Carbs. The BS34's are a good stock motor street Karb. But for what you have those Smoothies will be the go! Get them in top shape, you will be glad you did it.
  • Old Man Rock
  • Old Man Rock's Avatar
24 Nov 2011 10:05 - 24 Nov 2011 10:16
#489963
BS-34:
via Z1...
OEM
Attachment MukuniCarbsIdentification.JPG not found
Smooth Bores
Attachment MikuniVM29SmoothBores.jpg not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 24 Nov 2011 10:16 by Old Man Rock.
