1980 KZ550 Vacuum Lines
- 1980kz550
21 Jun 2011 00:31
Hello,
I am new to the board, my uncle recently gave me a 1980 KZ550 that somebody gave him with half the bike in a box. So, I got the carbs on and figured the wiring out and got it started with a small engine fire on sunday
. But I noticed it has 2 vacuum ports pointing straight back out of the carbs, and one attached to the petcock. If somebody could tell me where these go or maybe has a vacuum diagram for this bike it would be greatly appreciated.
Thanks,
Nick
Thanks,
Nick
Re: 1980 KZ550 Vacuum Lines
21 Jun 2011 01:00 - 21 Jun 2011 05:571980kz550 wrote: Hello,
I am new to the board, my uncle recently gave me a 1980 KZ550 that somebody gave him with half the bike in a box. So, I got the carbs on and figured the wiring out and got it started with a small engine fire on sunday. But I noticed it has 2 vacuum ports pointing straight back out of the carbs, and one attached to the petcock. If somebody could tell me where these go or maybe has a vacuum diagram for this bike it would be greatly appreciated.
Thanks,
Nick
Hello, Nick, and WELCOME to KZr!
Unused vacuum nipples should be capped (plugged).
In other words, no vacuum port should remain open to air.
One of the vacuum ports may be used to supply vacuum to a vacuum operated petcock.
Some carb designs have 4 vacuum ports.*
Other carb designs have a 5th vacuum port dedicated to the vacuum petcock.
Four vacuum ports are used simultaneously when synchronizing the carbs.
Not to be confused with vent nipples (usually two) that vent the float bowls and should exit via attached tubes to open air typically routed to exit underneath the seat or routed down around the swing arm to exit underneath the bike.
Here's an example of carbs with a 5th vacuum port.
Edit -- vacuum ports are on the carb holders (between carb and engine).
Last edit: 21 Jun 2011 05:57 by Patton.
Last edit: 21 Jun 2011 01:06 by Patton.
21 Jun 2011 01:10
There's lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- loudhvx
21 Jun 2011 02:46 - 21 Jun 2011 02:47
The two small hoses are bowl vents. They route upward toward the top of the airbox and just lay there open (as Patton mentioned). The first page of the TK-22 webpage has the vac lines labeled. Click on the photo to enlarge it):
home.comcast.net/~loudgpz/GPZweb/TK22mainPage/TK22mainPage.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 21 Jun 2011 02:47 by loudhvx.
- 1980kz550
21 Jun 2011 22:04
Wow, you guys are quick and thorough. That about covers it, I should be able to have her runnin' this weekend now. The info is much appreciated!
Thanks,
Nick
Thanks,
Nick
