carb bowl and top screw sizes
- wireman
13 Apr 2011 04:54
does anybody know the size and length of top and bottem bowl screws for vm 26-28 carbs?
how about the bs 34s? i cant tell what those little things are ! :sick: :laugh:
- OnkelB
Re: carb bowl and top screw sizes
13 Apr 2011 15:34
As for the BS 34s the top cover screws are 5 x 10 mm, the bowl screws are 5 x 15 mm, pitch is 0.8 mm (standard metric pitch).
I believe the stock screws might be slightly different (shorter) in length, but 5 x 10 and 5 x 15 are standard metric sizes and will work.
Don't know for sure about the VM26 - 28s, but I would suspect 4 mm (0.7 mm pitch) as on the VM 24s.
77 KZ 650 B1, 82 GPz 1100 B2.
- wireman
13 Apr 2011 16:08
thanks!
- OnkelB
13 Apr 2011 17:10
No problem.
- Kidkawie
- I bleed premix
13 Apr 2011 17:19
Z1E sells bags of them to do a set of carbs, has listings for the right sizes.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Mcdroid
- Gone Kwackers
13 Apr 2011 17:22wireman wrote: does anybody know the size and length of top and bottem bowl screws for vm 26-28 carbs?
Jim...I have a set of VM26's off my bike. If you still need those measurements, I can, if I freakin' remember, get them tonight and post.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- wireman
13 Apr 2011 19:19his are phillips head,i want stainless steel allen heads.Kidkawie wrote: Z1E sells bags of them to do a set of carbs, has listings for the right sizes.
ordered enough of them today for about 25 sets of carbs,should be a good start anyway.
- Kidkawie
- I bleed premix
13 Apr 2011 21:41
Sometimes the description for the Kaw part number will list the size. Bearings, bolts, nuts, shafts, etc.
1975 Z1 900
2004 KX125
2004 KX125
