bs 34
- kawastrtfgtr
- TerryK
Re: bs 34
06 Dec 2010 11:21
Does anyone know what you just said?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Re: bs 34
06 Dec 2010 11:43
kawastrtfgtr wrote:
A dirty pilot circuit could be one possible cause of poor performance at lower rpm.
does any body know why its die up to rpm 5500?
- baldy110
Re: bs 34
06 Dec 2010 18:35
That is the same as asking someone, "My car won't start, do you know why?" We need a little more info.
- kawastrtfgtr
Re: bs 34
07 Dec 2010 00:42
i started it and it works not good performance' and its warm up its better, i guess carb problem. when accelarition, it comes to 5500-6000 rpm; it coughs. and dont increase the rpm gauge 6000 and up. this is my kz1000 problem...
Re: bs 34
07 Dec 2010 06:43 - 07 Dec 2010 06:45
kawastrtfgtr wrote:
Some possible causes per FSM:
Last edit: 07 Dec 2010 06:45 by Patton.
- kawastrtfgtr
- kawastrtfgtr
Re: bs 34
07 Dec 2010 10:19
May usually click on any posted image to see a larger view.
