bs 34
  • kawastrtfgtr
  • kawastrtfgtr's Avatar Topic Author
bs 34
06 Dec 2010 11:08
#415660
does any body know why its die up to rpm 5500?
  • TerryK
  • TerryK's Avatar
Re: bs 34
06 Dec 2010 11:21
#415661
Does anyone know what you just said?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Re: bs 34
06 Dec 2010 11:43
#415663
A dirty pilot circuit could be one possible cause of poor performance at lower rpm.
Good Fortune! :)
  • baldy110
  • baldy110's Avatar
Re: bs 34
06 Dec 2010 18:35
#415722
That is the same as asking someone, "My car won't start, do you know why?" We need a little more info.
  • kawastrtfgtr
Re: bs 34
07 Dec 2010 00:42
#415749
i started it and it works not good performance' and its warm up its better, i guess carb problem. when accelarition, it comes to 5500-6000 rpm; it coughs. and dont increase the rpm gauge 6000 and up. this is my kz1000 problem...
Re: bs 34
07 Dec 2010 06:43 - 07 Dec 2010 06:45
#415769
Some possible causes per FSM:
Good Fortune! :)
Last edit: 07 Dec 2010 06:45 by Patton.
  • kawastrtfgtr
Re: bs 34
07 Dec 2010 09:25
#415784
thanks for ideas
  • kawastrtfgtr
Re: bs 34
07 Dec 2010 10:06
#415791
how to adjust the float high level?
Re: bs 34
07 Dec 2010 10:15
#415793
Do a search on clear tube test. :)
Re: bs 34
07 Dec 2010 10:17
#415794
Re: bs 34
07 Dec 2010 10:18
#415795
Re: bs 34
07 Dec 2010 10:19
#415797
May usually click on any posted image to see a larger view.
Good Fortune! :)
