where to get new slides for the bs 34mm mikuni????
- otakar
Re: where to get new slides for the bs 34mm mikuni????
26 Jul 2010 16:30 - 26 Jul 2010 16:32
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Jul 2010 16:32 by otakar.
- otakar
26 Jul 2010 16:32 - 26 Jul 2010 16:36
Another picture. Because there is no key from rubber to slide there is no key on the lip of the rubber. Everyone who is smart enough to be able to change the rubber will be smart enough to know how to index the slide in the carb body. I will have pricing in a couple of days on them, but it will be most likely $125 for the four rubbers plus post. These will work on all Mikuni BS34 KZ700/750/1000/1100 carbs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Jul 2010 16:36 by otakar.
- Mcdroid
- Gone Kwackers
26 Jul 2010 16:40
Thanks for keeping us posted Otto. I picked up a set of BS34's...just to have. Glad to know you may have diaphragm replacements.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
26 Jul 2010 19:15
Just found out from the molder that he is sending me three sets this week. These are production test shots and will be of production quality. If anyone requires some. I still don't have a definite price though just the estimated minimum price he gave me. So the $125 is the price for now until he raises my price.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- ready2ryde1985
- got to love these kzs
26 Jul 2010 19:32
In the wise words of sponge bob "Its the best day ever!"
:laugh: So ready be shure to let me know how those work out I have about a month or two of riding left but I will have the $$$ for ya shortly after sturgis!!
Hope my kz does good up there round all them HDs
:silly:
:silly:
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- otakar
23 Sep 2010 07:06
Production "rubbers" are ready. I am very happy with the new material we are using and the quality of the product itself. They are a little softer than OE Mikuni and just as soft as OE Keihin rubbers. This should produce a bit faster response and no binding, such as can be experienced with older rubbers. All that has to be done to use these is to cut off the old rubbers and the retaining rings and slip on the new rubber. They can be glued on if you wish but I dont think it will be necessary.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Mcdroid
- Gone Kwackers
23 Sep 2010 07:08
Otto...what might you be wanting for a set of four?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ready2ryde1985
23 Sep 2010 18:30
somethin like 130 + shiping not bad and you can do it all your self .
I plan on using a set and will post my results
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- otakar
26 Sep 2010 08:59
I now only have three sets left. Just so you guys know.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- WICKEDKZ
29 Sep 2010 06:10
these diaphragms can be bought off ebay for $19 a piece, don't know where oktar is justifying making $50 on a set of 4,guess being "middleman" pays off ($130 + shipping) lmao
- WICKEDKZ
29 Sep 2010 06:11Please Log in or Create an account to join the conversation.
- otakar
29 Sep 2010 14:52 - 29 Sep 2010 15:35
Go and buy some of those. They are made out of the same material as what the boots are made out of that go from the carbs to a OE airbox, and they are 80 shore A hardness. Mine are made out of Nitrile rubber and are shore 55 hardness. Once you install them you will find the difference real quick. Also you are aware how hard those boots get once they get exposed to heat a few times and to Gasoline. I bought those rubbers and tried them. It took a total of over 15oz Yes almost 1lb, to compress them. It takes 1.7oz to compress mine. Now imagine how they will react in a carburetor wit only vacuum moving them and being under spring load. You are not showing me something that I do not already know and have not already tried.
As you can see on this picture with the other guys diaphragm at the bottom. There is a Nology ignition coil, a KZ1000 cam cap with bearings and a small flash light (not visible) stacked on top of this rubber. The scale is showing 12oz and the diaphragm is still holding. These will work fine in a constant speed Rotax engine for ultralight aircraft when you slowly throttle up and hold constant throttle. They however will not respond to the usual "cracked" throttle on a bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Sep 2010 15:35 by otakar.
