where to get new slides for the bs 34mm mikuni????
- ready2ryde1985
- got to love these kzs
11 Jun 2010 21:04
I am still fine tunen my kz 700 and would like to know if anyone has found a cheep source for these vaccume slides in the top of the bs 34mm ..
what is a better carb i have been told for better throtle responce i would want flat slides or any manual slide carb.?
what is a carb that would alow me to go from the 700 cc to a 715 to a 810 late in this bikes life . i know that the rs 34mm is suposed to be an up grade but isnt that to much carb for my stock bike with no real head work ??
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- bountyhunter
Re: where to get new slides for the bs 34mm mikuni????
11 Jun 2010 22:33 - 11 Jun 2010 22:35
A little while back I got a good used set of slides for my BS-38 Mikunis from a parts dismantler online. I think I paid $80. I've had pretty good luck with them.
I don't know about putting on different carbs. The intake/exhaust are tuned so tight and matched to the carb flow characteristics.
Last edit: 11 Jun 2010 22:35 by bountyhunter.
- Mcdroid
- Gone Kwackers
12 Jun 2010 07:34
If you are interested in just the diaphragms, contact these people:
www.motorradbay.de/main/lang.php?cw=1
If the actual slides are bad, then eBay is your source.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
12 Jun 2010 07:45
The BS34 is already a very large carb for the 700-800cc engine. These carbs are perfect for engines in the 1000-1200cc engine size. They have an accurate sweep area of 735mm/2 that is equivalent to a 31.5mm smooth-bore carb. Most people have determined that a 29mmSB is the ideal size for a 1000-1100cc motor, and that a 33mmSB is way too large. If you want a manual slide carb for your bike that would be perfect than a 26-28mm carb from a KZ1000 would work very well and would bolt right on. The BS34s mounted on the 750s are way detuned to work well on the bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- ready2ryde1985
12 Jun 2010 08:18
Thanks for all the info havent found my bs rubbers on that site guess I will have to look alittle harder whan I get home .. I do not think the slides are bad but the rubber is like 26 years old and wore out.
So my bs 34 mm are good carbs ?? guess i will just have to learn to love them lol. I do like the rs 34 flat slides and herd they had alot more throttle response .But i can use that 800 bucks on head porting and cams or a new pipe.
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- ready2ryde1985
12 Jun 2010 08:27
Did not se the diaphragm for the bs 34mm thanks for the info I will keep looking mabe they are out of stock.
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- Mcdroid
- Gone Kwackers
12 Jun 2010 10:45
Yeah...I didn't look closely enough...they apparently don't carry them. However, if your bike has Mikuni BS34's, then you can use the diaphragms from the 1982 KZ750R1, which also uses the same carbs (different jetting). The site below does carry them, but they are pricey.
www.nrp-carbs.co.uk/
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Buda
12 Jun 2010 14:52
Ebay is where I got mine,$100 for the set of carbs.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
12 Jun 2010 15:00
Do your diaphragms have holes in them? If so are they pin holes or are they torn? Please show us a picture of the worst one you have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- ready2ryde1985
12 Jun 2010 15:07
So thoes are like 50 a piece after shiping right?? I dont have to buy new carbs mine arnt that bad . how many bad sets of 34s for 100 bucks are on ebay cause they didnt want to replace the vaccum rubbers lol. I have replaced most of the parts on my bike but these dam diaphrams are a pain to find !!!
Thanks for the help!! hope to order thoes next just ordered the tank lid gasket and carb holders from z 1 so mabe my bike will idle then the diaphrams .. any other advice ?? I am new to bikes but i am lovin this riden.
also the holders i got are for the 650 750 will thoes work or should i have bought the 1000cc kit??
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- ready2ryde1985
12 Jun 2010 15:12
I am curently riding my bike but when i pull the carbs off to put the new holders on i will take pics. My need for replacing them is more prevenitive mantince . Hell i have a hole clutch kit sitn on the shelf just waitn to feel a slip lol.
i like to stay on top of the little things so that when there is a problem i dont have to wait for parts
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- bountyhunter
13 Jun 2010 00:10
ready2ryde1985 wrote:
Yeah, but on most of the rubbers they require you send them the slides and let them install them. That was my gripe, not the price. I didn't want to risk losing good slides in the mail going across the pond.So thoes are like 50 a piece after shiping right??
