29 smoothbores
- chelms27
29 smoothbores
26 Nov 2008 09:32
I found a set of supposedly 29 smoothbores from a friend and have a couple of questions. How can I tell what they are?, are there any numbers to check? I plan on putting them on my 77 1000. Thanks for any help.
1977 KZ1000...16k miles 2nd owner all original except tires, dyna-coil, and a vance and hines 4 to 1 exhaust.
Re: 29 smoothbores
26 Nov 2008 10:18
chelms27 wrote:
Could compare with pics in Z1E's carb info section.
And perhaps post some pics here in this thread for us to see and advise about.
Good Luck!
Good Luck!
- chelms27
Re: 29 smoothbores
26 Nov 2008 10:25
where is the Z1E carb info section? I will try and get some pictures up...isnt there a number under the choke or something?
- steell
Re: 29 smoothbores
26 Nov 2008 10:53
chelms27 wrote:
www.z1enterprises.com/reference/z1-carb-guide.aspx
- timebomb33
Re: 29 smoothbores
26 Nov 2008 13:18
first check is the easiest they have a 17mm headed drain plug on the bootom of the float bowl.
I THINK MY POWERBAND BROKE
- steell
Re: 29 smoothbores
26 Nov 2008 14:44 - 26 Nov 2008 14:48
timebomb33 wrote:
Guess that would mean they are either 29's, or 28's
Z1 link in my last post.
And from the same link.
The early Z1 28mm carburetors are best identified by the combination of 17mm drain plug directly under the main jet,
Mikuni 29mm smoothbore carbs
The top of the carb is identical to the 26mm (and later KZ1000 28mm) carbs. The float bowl went back to using the 17mm drain plug directly under the main jet. Great for racers as it allowed for quick changes of the main jet. None of the VM29's have an overflow pipe fitted in the float bowl.
l Note: some very early sets of 29mm smoothbore carbs have a float bowl with a small drain screw angled to the side.
Last edit: 26 Nov 2008 14:48 by steell.
- timebomb33
Re: 29 smoothbores
26 Nov 2008 14:53
the zi 28mm carbs had two screws holding down the top caps the 29 smoothbores look very similar to stock late model carbs [26 or 28mm] three screws in the top cap. the 29's are the that have the 17mm drain plugs
- racer54
Re: 29 smoothbores
26 Nov 2008 15:59
One of the ways to tell is also to look for the small square recess on the side of the carbs. Not sure which carb, offhand, but it's on an outside carb.
- PLUMMEN
Re: 29 smoothbores
26 Nov 2008 18:57
timebomb33 wrote:
we used to put float bowls off of 26s on them just sopeople wouldnt know what they are!:laugh:the zi 28mm carbs had two screws holding down the top caps the 29 smoothbores look very similar to stock late model carbs [26 or 28mm] three screws in the top cap. the 29's are the that have the 17mm drain plugs
- Bluemeanie
Re: 29 smoothbores
26 Nov 2008 19:03 - 26 Nov 2008 19:04
chelms27 wrote:
Along with steell's link...
Last edit: 26 Nov 2008 19:04 by Bluemeanie.
- roadracer
- i love motorcycles
Re: 29 smoothbores
26 Nov 2008 19:26
on right hand side of carbs as if you were sitting on bike there is a insert between manifold side and carb body. there are numbers there and it will be stamped 29. otherwise just look at airbox side, lots of difference there. hope it helps
- wiredgeorge
Re: 29 smoothbores
26 Nov 2008 21:03
Plummen... I don't believe the bowls will interchange from a VM26 to a VM29. the 29 bowl is quite a bit larger and shaped differently.
