Engine Forum
Engine forum is a tech forum for "Engine" topics.
And you thought you were through with me
  • Wildh2oskier
  • Wildh2oskier's Avatar Topic Author
15 Jun 2008 19:40
#220235
OK we now have the Screaming Flaming Kawasaki of the Appocolypse (my 1983 KZ 750 twin)running quite well with its synched carbs with no vaccume leak and good fuel flow into the unit.
However as I discoverd today starting this beast when it hasn't ran for a few hours is extemely hard to do. I know the first answer your going to think of (I thought of it too) "Go ride it every couple of hours". Of course the bosses at work and my family requirements make that a practical impossibility.
So what I have to do is get it to the point of where it starts easily.
Here are the symptoms of todays problems.
Key switch on.
Handlebar Kill Switch on.
Clutch engaged with engine in neutral.
Choke on.
Press starter button.
Run starter till battery is nearly exhausted.
Bike sometimes spits, pops and slowly comes to life like one of those hit-n-miss engines.
The plugs are staying dry and the fire is real good so I'm guessing .... its a carb issue (again):huh:
So where do I begin?
Thanks again in advance again.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: And you thought you were through with me
15 Jun 2008 19:56
#220239
#1 question - Have you done the "coil power mod" ?? The one made famous by WiredGeorge? It's mandatory as far as I'm concerned. It will help deliver full spark to the plugs, even when burdened by the electric start.
That, and a new coil...
:lol:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • Locozuna
  • Locozuna's Avatar
15 Jun 2008 19:58
#220240
OK I'm gonna be a smartass here. Have you tried with no choke? Seriously I have a 900 here that absolutely hates the choke. Stone cold just crank it for 3 seconds and she is snorting sweetly. Touch that choke and she turns into Cruella DeVille. I figured she had to be running rich but plugs always look good. Maybe yours is spooked too!:blink:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Wildh2oskier
15 Jun 2008 20:05
#220241
The coil is new.
I have tried it with no choke. Maybe I should try it without touching the throttle.
I'm grasping at straws here.
  • Makarth
  • Makarth's Avatar
16 Jun 2008 01:28
#220268
could always prime it with starting fluid
1977 kz1000 - Megasquirt project @ 40% wiring, plenum, and exhaust<--(done!)
  • Wildh2oskier
16 Jun 2008 03:52
#220273
Thats how I got it to start yesterday. I'm really not wanting to continue doing that.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
16 Jun 2008 05:02 - 04 Dec 2008 06:42
#220278
del
Last edit: 04 Dec 2008 06:42 by JMKZHI.
  • steell
  • steell's Avatar
16 Jun 2008 05:16
#220280
Do "NOT" touch the throttle when using the choke (it's not really a choke, but most call it that). Turn on the petcock, turn on the choke to full, turn on the key, squeeze the clutch lever, hit the starter button, that's it, don't touch the throttle.
  • wiredgeorge
  • wiredgeorge's Avatar
16 Jun 2008 07:10
#220293
The choke on your carbs is an enrichener circuit that will NOT pull gas if you have the throttle opened. You probably need to clean the pilot and enrichener circuits internal to both carb bodies. It likely wouldn't do any harm to replace the pilot jets.
  • ronjones
  • ronjones's Avatar
16 Jun 2008 14:01
#220362
Wildh2oskier wrote:
The coil is new.
The coil mod, that Toast suggested, has nothing to do w/a new or old coil. The wiring in these old bikes get funky. The mod uses a relay to get full power from the battery directly to the coil. If you ain't gettin' full power to the coil, she ain't gonna start well, cold, using the starter. If everything is working right, she should start w/a couple of kicks w/the kickstarter, even cold.
  • bountyhunter
  • bountyhunter's Avatar
16 Jun 2008 14:07 - 16 Jun 2008 14:11
#220365
Mine has the "manual idle adjuster" on the side. When I go to restart, first I turn that up just a tad to where the bike would be hot idling at maybe 1500 rpm. That's about right for a cold start.
If the bike is DEAD COLD, pull the choke on almost all the way.
If it's been sitting maybe 1/2 - 1 hour, I don't need the choke.
2 or 3 hours, apply just a bit of choke.
NEVER crank on the throttle as you are trying to start it. Just set the thing to about the right idle point and that's it until it fires up.
FYI: the problem I have seen that will make a bike a cranky starter in the 1 - 2 hour range is the needle jets may not be seating tight, or the fuel levels may be too high. As the bike sits, gas seeps by the needle and fills the bowl and lets some seep into the bore (flooding it).
Do you always turn the petcock OFF each time you stop?
Is the petcock sealing well?
Last edit: 16 Jun 2008 14:11 by bountyhunter.
  • Wildh2oskier
16 Jun 2008 16:59
#220393
The petcock has a prime, on, and reserve settings. I tried it today and it took a minute or two of spinning the engine but it fired up.
Now where do I find out more on this coil modification?
