Plug came off of carb holder tube - will this hurt performance?
  • elcid
  • elcid's Avatar Topic Author
10 Apr 2008 23:59 - 10 Apr 2008 23:59
#205621
Check the diagram here:
go to number 16 & 17. I lost this rubber cap. Will this hurt performance? What are these tubes for any way??
Last edit: 10 Apr 2008 23:59 by elcid.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Plug came off of carb holder tube - will this hurt performance?
11 Apr 2008 00:28
#205626
They are for hooking up external vacuum gauges to check the balance between your carbs...and yes, those ports need to be blocked at all times (either with a vacuum gauge or the plugs) (Z1Enterprises sells them individually).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JMKZHI
  • JMKZHI's Avatar
Re: .
11 Apr 2008 05:08 - 04 Dec 2008 05:54
#205645
del
Last edit: 04 Dec 2008 05:54 by JMKZHI.
  • BSKZ650
  • BSKZ650's Avatar
11 Apr 2008 05:19
#205651
as a temp fix you can get vaccum plugs at the parts store
77 ltd1000, current rider
76 kz900, just waiting
  • Z1109R Fin
  • Z1109R Fin's Avatar
11 Apr 2008 05:40
#205660
On the other hand you´ll get cruise control since revs won´t go down:P No, seriously, teh must be closed all times otherwise the air/fuel -mixture goes nuts and it runs like crap.
Z1000R ´83...Slightly modified...
  • wiredgeorge
  • wiredgeorge's Avatar
11 Apr 2008 05:47
#205663
I wouldn't run a bike with a cap missing. Makes that cylinder run REAL WARM!
  • elcid
11 Apr 2008 09:36
#205717
I was wondering my bike starting running crappy! I just had the carbs retuned a few weeks ago & it was running so smooth. Then I noticed some "weirdness" & thought man they go out of sync that soon?? Then I looked & saw one of those rubber caps missing. It didn't dawn on me until yesterday that that could be the cause. I went down to home depot & got this cap & put it on there. And BAM it runs smoothly again! YES! But do I need the exact ones from Z1 that are made for that purpose or can I use any rubber cap that seals it?
  • RonKZ650
  • RonKZ650's Avatar
11 Apr 2008 09:56
#205726
Better get the right kind, made for gas. I'd bet Home depot rubber with get saturated with gas before the day is over.
  • elcid
11 Apr 2008 10:25
#205739
couldn't I get something like that from an auto parts store?
  • RonKZ650
  • RonKZ650's Avatar
11 Apr 2008 11:57
#205764
Probably, otherwise in a pinch you can use a short hose plugged with a bolt or something to that effect.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
11 Apr 2008 18:28
#205825
Keep riding without the plug and you'll be replacing at least a piston...
-duck
  • elcid
11 Apr 2008 19:39
#205830
Got some caps from my local Autozone. They're made by "vacu-tite" so I hope they will work. Time will tell...
