Exhaust Pipe Rechrome
- gene
17 Dec 2011 14:46
I think I have finally decided to rechrome the pipes for my '77 KZ1000 LTD only because the alternative is modification to new pipes to get them to fit. Will I need to remove the baffles first? If so, has anyone removed tack welded in baffles? I figured I could probably cut them out with my dremel tool and then grind the welds smooth. To put them back in I'd drill and tap and put them in with a couple screws. any thoughts on this?
Last edit: 18 Feb 2013 18:42 by martin_csr.
- Mcdroid
- Gone Kwackers
Re: Exhaust Pipe Rechrome
17 Dec 2011 19:48martin_csr wrote: I would ask the rechromers. I really don't know much about it, but I kinda wonder if they will even do used pipes, because the carbon & rust n stuff will contaminate their chemicals.
+1 on what Martin said...the deposits in the pipes contaminate the chroming baths...but you might get lucky.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- andy9802gt
- If it tastes that good, eat it yourself.
17 Dec 2011 22:13Mcdroid wrote:martin_csr wrote: I would ask the rechromers. I really don't know much about it, but I kinda wonder if they will even do used pipes, because the carbon & rust n stuff will contaminate their chemicals.
I would think you could take the pipe and have the inside blasted to remove any carbon deposits or rust first.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- bountyhunter
18 Dec 2011 16:23Not around here. The guy had some choice words about what it would do to his plating tank.martin_csr wrote: I would ask the rechromers. I really don't know much about it, but I kinda wonder if they will even do used pipes, because the carbon & rust n stuff will contaminate their chemicals.
- SPARKY47
- 1980 KZ500 B2
18 Dec 2011 16:44
Years ago we used to take the pipe off,block the downpipe end and stand it up then fill with a strong solution of caustic soda.It dissolves the carbon and muck.Leave overnight.Any reason you can't do that?It would keep the plating man happy.
1980 KZ500 B2
