Oil filter washer...
  • racer54
  • racer54's Avatar Topic Author
15 Aug 2011 22:49
#469274
Tried to find a parts diagram that would show this but can't find one anywhere that has a parts diagram. I have seen them on here but can't find where you guys come up with them so...what I need to know is...is there a steel flat washer that sits on top of the spring under the oil filter...or does the spring ride against the rubber on the bottom of the oil filter? While we are at it, where do you guys find those parts diagrams. I checked Kawasaki.com but couldn't bring up any diagrams for a KZ1000?
  • Motor Head
  • Motor Head's Avatar
Re: Oil filter washer...
15 Aug 2011 23:00
#469275
  • racer54
15 Aug 2011 23:03
#469276
Cool! Quick and fast...glad you were sitting there waiting for my question!:laugh: Thanks...thought there was supposed to be one but wasn't sure. Don't have one on my filter for quite awhile and didn't give it much thought til know. Have to see if I can find one around here somewhere!
  • racer54
15 Aug 2011 23:05
#469277
OK...next question...where on that site did you find the diagrams? I can't find them.
  • Motor Head
15 Aug 2011 23:08
#469279
I'm using Firefox, so if you can't click and open that link, then copy and paste it in your browsers address bar.
Other wise it is just cyclepartsnation.com, and do a OEM parts search under Kawasaki.
  • racer54
15 Aug 2011 23:08
#469280
Found them!
15 Aug 2011 23:58
#469293
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • racer54
16 Aug 2011 00:38
#469303
Yea...I tried there but couldn't pull up any parts diagrams for these older bikes. Must have been doing something wrong.
  • jms3257
  • jms3257's Avatar
16 Aug 2011 10:31
#469349
Back to the original question about the washer, racer54 you said you haven’t had the washer for quite a while. Have you had any problem without it? I just changed the oil over the weekend, haven’t had the bike long, (1980 KZ1000 LTD) and I don’t recall having that washer.
Jim:
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
  • martin_csr
  • martin_csr's Avatar
Re: .
16 Aug 2011 10:36 - 22 Jan 2013 05:02
#469350
Last edit: 22 Jan 2013 05:02 by martin_csr.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
16 Aug 2011 10:55
#469353
jms3257 wrote: Back to the original question about the washer, racer54 you said you haven’t had the washer for quite a while. Have you had any problem without it? I just changed the oil over the weekend, haven’t had the bike long, (1980 KZ1000 LTD) and I don’t recall having that washer.
Jim:
Those washers are often thrown away with the old filter when the owner doesn't realize what it is and that it's just adhered to the rubber seal on the filter. The official line is that they keep the rubber seal from being pushed into the filter.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • RonKZ650
  • RonKZ650's Avatar
16 Aug 2011 11:11
#469357
The washer is not critical. No harm comes from not using it.
