Changing Sprokets
  • Jay650
  • Jay650's Avatar Topic Author
Changing Sprokets
17 May 2011 20:55
#451782
I have an 81 kz650. im getting anywhere from 38-45 miles per gallon, which i dont think is all to bad with this bike. however my question is, i have heard of people changing rear sprokets to get better gas mileage or power. will that make a difference in gas mileage, and what will i sacrifice by changing the sproket. my bike as far as i know is all stock at this point
  • hocbj23
  • hocbj23's Avatar
Re: Changing Sprokets
17 May 2011 21:15
#451785
With every tooth down u go on the rear sprocket, and /or every tooth up u go on the front sprocket,ur cruising rpm will drop which equates to better mpg. The trade off is that u will lose some of your available power,especially at low to mid range rpm.Your call,better mileage vs. better low to midrange power.On a stock 650, I would personally leave the sprockets alone but again,your bike,your call.Good luck.I imagine Z1Enterprises has all sorts of sprockets available and will be able to supply what u want OR give u a good source.bj
  • martin_csr
  • martin_csr's Avatar
Re: -
17 May 2011 21:16 - 14 Feb 2013 11:20
#451786
Last edit: 14 Feb 2013 11:20 by martin_csr.
  • MFolks
  • MFolks's Avatar
17 May 2011 21:27
#451791
www.gearingcommander.com is what I use when changing sprockets.
  • Jay650
17 May 2011 22:12
#451810
this is the first year i have ridden this bike, but it does seem to cruise at higher rpms then i would have expected, almost like it needs another gear. so maybe going with a 30t rear sproket would help. worst that happens, i dont like it and swap it back right. wouldnt be any fun if you didnt try to change anything.
17 May 2011 23:57
#451833
The standard engine sprocket on the KZ650-C1 and B1 models is 16T and Kawasaki offered a 17T one for racing applications, so if you decide to change it you can go pretty big. However, as you point out, changing the rear is easier and much less hassle to change back if you don't like the results. I doubt, however, that you'll ever get over 45 mpg unless you sacrifice a lot. With the standard 16/42T on my C1 I don't believe I've ever gotten more than 36 mpg. Ed
  • martin_csr
Re: .
18 May 2011 00:42 - 14 Feb 2013 11:14
#451842
Last edit: 14 Feb 2013 11:14 by martin_csr.
  • steell
  • steell's Avatar
18 May 2011 01:19
#451845
Maybe because the CSR uses a 630 chain while the earlier models use a 530 chain? :)
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
18 May 2011 01:51
#451849
I really disagree with many of the stated opinions in this thread. Yes, you can change the ratios but that will not directly correlate to fuel mileage improvements. Just because your engine is turning slower doesn't mean that you didn't have to reach deeper into the throttle to get there and stay there.
My experience is that MA Kaw is pretty damn smart about gearing her bikes. I changed to a larger front sprocket on my 900 just to slow down the cruising RPMs and while I did accomplish the drop I wanted I lost a lot of driveability in the lower four gears and I saw no improvement in fuel mileage.
Fuel consumption has more to do with available power and work performed than it does with engine speed.
IMHO
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • bountyhunter
  • bountyhunter's Avatar
18 May 2011 01:57
#451850
Don't assume a higher gear ratio will give better mileage. You have to open the throttle more so it may even be less mileage. I changed my rear gear from 38T to 32T and the mileage was the same. Cruising was smoother (lower RPM's) but acceleration was slower.
  • polarbear
  • polarbear's Avatar
18 May 2011 02:29
#451851
Personally, I would try to do everything to not change sprockets: clean fuel system, check/replace air/gas filter and spark plugs, tires properly inflated, everything well lubed, short shifting, etc. to see if mpg improves.
But please do let us know if you change anything and if it does change your mpg.
Good luck!
C
  • wireman
  • wireman's Avatar
18 May 2011 03:09
#451853
check the air in your tires B)
