VM28 float level
- sf4t7
VM28 float level
26 Mar 2024 08:41
OK so here's my dumb question for the day: Checking float level with the clear tube, is it 1/8" down from the float bowl gasket surface or from the lip at the bottom of the carb body? Illustration in the FSM looks like it's from the bottom edge of the lip.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Warren3200gt
Re: VM28 float level
26 Mar 2024 08:59
The mating surface of the bowl and body. 2-4mm. So aim for 3mm.
26 Mar 2024 10:11 - 26 Mar 2024 10:12
Last edit: 26 Mar 2024 10:12 by Nessism.
- Rolf1976_KZ900
26 Mar 2024 11:49Please Log in or Create an account to join the conversation.
- Rolf1976_KZ900
26 Mar 2024 12:17 - 26 Mar 2024 14:23
if curius on what the float height is i did this test .It is a very good test to check if the float valve leaks and at what height the floatvalve opens.My carbs had a height at 25mm at 25,5mm they leak.
Here is a link to the test i use from themotorcyclemd .
Last edit: 26 Mar 2024 14:23 by Rolf1976_KZ900.
- Rolf1976_KZ900
26 Mar 2024 14:14 - 26 Mar 2024 14:18
ups i forgot that i have carbs for kz1000 on my bike but they are vm28 I think ? i will check again in a earlier tread .
Okay update i have vm26 carbs.
Last edit: 26 Mar 2024 14:18 by Rolf1976_KZ900.
- sf4t7
26 Mar 2024 15:09
Thanks Ed. I couldn't decide if the FSM was referring to the bottom of the body or the top edge of the float bowl. And then I started overthinking it...
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- slmjim+Z1BEBE
26 Mar 2024 17:47What manual is that illustration from?
The Z1 'White' FSM reads "About 1/8" " there. The ambiguous "About" always drove slmjim nuts. Still does.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Cra-z1
27 Mar 2024 17:30 - 27 Mar 2024 17:31
I always set it just to the top of the split washer on the bowl screw.
Last edit: 27 Mar 2024 17:31 by Cra-z1.
