To strip or not to strip?
- Bicycle Lee
11 Feb 2008 10:51
So I am starting to get ancy for the warm weather and I want to start some paint removal on my gas tank. It has been rattle-canned with god only knows how many coats. I was wondering what the people here thought as to the preferred method of paint removal. Do I put a paint stripper on it? Do I just sand the hell out of it?
1978 KZ1000 police
- mariozappa
Re: To strip or not to strip?
11 Feb 2008 11:03
If it's been rattle canned, you can buy Aircraft Remover at wal-mart. It will eat the paint right off the metal. Temps above 70 degrees help it work too.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- riverroad
- 1980 1000LTD B4
11 Feb 2008 11:12
I like to use a stripper on rattle can paints. I usually use an abrasive wheel in my die grinder, but rattle can paint always seems to smear around a lot.
I found some stripper at Lowes that smells like oranges and it works really well. While you're there buy some small wire brushes to get in the nooks and crannies.
I've also used a heat gun to remove paint, but I probably wouldn't try it on a gas tank, unless I was sure all of the gas fumes are gone. And if you completely dry the tank of gas for any length of time, you should slosh some motor oil around in it to keep it from rusting.
Another thing is, if you strip the outside of it now, then wait for warm weather to re paint it, you need to protect the tank from rust. I use Dupont metal prep for that.
- Bicycle Lee
11 Feb 2008 11:18
thanks. And Riverroad: I love your avatar photo!
1978 KZ1000 police
- jcote75
11 Feb 2008 12:28
Based coat / clear coat or many other paint can react on what is underneath. (specialy over cheap rattle can paint)
Or you could probably use a good sealer. but best wait is to strip it.
- 650 in Vegas
11 Feb 2008 18:53
I agree with everone who has poster so far. The only other advice I would give is to be very careful with the stripper if there are any patches of bondo (or any other filler) underneath all of that paint. Bondo is so porous that it has a really nasty habit of absorbing stripper and slowly releasing it after you have put a few coats of paint over it causing a real mess. No ammount of final sanding or sealing will fix this. Most commercial strippers have very specific directions on how to neutralize and prep an area for paint after you are done stripping, so if you follow the directions on the stripper exactly you will not have any problems. Just be very careful and don't cut any corners. Good luck and be sure to post pictures when you're done.
79 KZ650 C - The best $200 I have ever spent!
- Mark Wing
11 Feb 2008 20:14
Be careful with the stripper on the plastic parts.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Bicycle Lee
11 Feb 2008 20:32
thanks to everyone who posted. I got a can of spray stripper that has worked really well so far. I certainly have a couple bondo spots that I'll have to treat before painting.
1978 KZ1000 police
- Bicycle Lee
12 Feb 2008 12:43
so what do you treat the bondo spots with to ensure they don't ruin your future paint?
1978 KZ1000 police
- jcote75
12 Feb 2008 13:02
I would grind all the bondo off and start it back.
Just in case rust would had started under the bondo.
You'll passainr a few hours stripping, sanding and painting the tank + a few $$. So why not assure you that everything is fine underneath the bondo.
My 2ยข has they say!
Joce
Joce
- Bicycle Lee
17 Feb 2008 10:41
one more question: if I want to rinse out my tank to get out any foreign material that may have found it's way in there what should I use? Just water? Gas?
1978 KZ1000 police
- Little B
17 Feb 2008 11:09
Bicycle Lee wrote:
I'd wear gloves and use Acetone to do this.
1981 KZ750-H2 LTD
