Right handlebar lightswitch. and a leftover wire
  • Blind Alex
  • Blind Alex's Avatar Topic Author
06 Nov 2026 07:56
#928946
Hi FoIks,
I have a question regarding the wiring connections for the right-hand handlebar switch (original Z1000J).Here’s the situation: I recently became the proud owner of a set of Mikuni RS 34 flat-slide carburetors. As is often the case when you make modifications, further adjustments are required—in this instance, because these carburetors are operated by two throttle cables. The carburetors came with a throttle assembly (from a Ducati) that accommodates two cables.However, there is no longer enough room on my clip-on handlebar for the original Kawasaki switch housing; it’s too wide to fit alongside the new throttle assembly. I decided to look for a narrower replacement switch. I found a unit from a Ducati that also includes light controls. Naturally, the wiring for this Ducati unit needs to be modified to match the Kawasaki’s connectors. I’ve already sorted out the connections for the starter button and kill switch (using the white 4-pin connector), but I’m struggling with the lighting connections.On the Kawasaki, the lighting wiring is routed through a red 6-pin connector.Two of these pins are for the oil pressure indicator, but those can be omitted since I’ve relocated that indicator elsewhere.That leaves four pins: two for the parking light circuit, and two for the main headlight circuit (one yellow/blue wire for the feed, and one blue wire for the return).On the Ducati switch, there are only three wires coming from the light switch: one for the parking light, one for the main headlight, and a black wire (possibly a ground?) that also originates from the switch. So, I have one wire (blue/yellow) left over!The light switch from the Ducati likely functions differently than the original Kawasaki handlebar switch.It’s possible that this remaining wire needs to be connected to one of the other wires—but I’m not entirely sure how to go about it, or which wire it should be connected to.Does anyone have any suggestions regarding the wiring, or what I should do with this leftover wire?Thanks in advance!
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: Right handlebar lightswitch. and a leftover wire
06 Nov 2026 08:30 - 06 Nov 2026 08:56
#928949
 My 77' KZ 1000 LTD has a two cable throttle stock and I was able to use the stock cables to install a set of RS 34's.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
Last edit: 06 Nov 2026 08:56 by Kelly E.
The following user(s) said Thank You: Blind Alex
  • Warren3200gt
  • Warren3200gt's Avatar
06 Nov 2026 08:33
#928950
Which region is your J from.?
The fsm has got several J wiring diagrams from different sales regions.
If you dont have the fsm message me and i'll send you a download link from my drop box.
The following user(s) said Thank You: StreetfighterKz, Blind Alex
  • Blind Alex
06 Nov 2026 08:35
#928951
Hi Warren, My Z is an european one. I'll live in the Netherlands
  • Blind Alex
06 Nov 2026 08:37
#928952
Ok, So the handlebar of an LTD would be an option Too
  • Warren3200gt
06 Nov 2026 08:41 - 06 Nov 2026 08:48
#928953
 I've sent you a download link for the fsm.
Last edit: 06 Nov 2026 08:48 by Warren3200gt.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Nov 2026 12:58
#928961
All the "J","K", and "M" have the single throttle cable with the BS34's - On mine I have used a ZX1400 throttle and a ZX6R switch. If you can source a wiring diagram for the Ducati model the switch came from I will be able to tell you what to connect where (is your bike using a stock "J" loom ?)
  • canman
  • canman's Avatar
09 Nov 2026 14:28
#929009
when using the ZX6R switch was that a match for the KZ 1000 J wiring loom plug ? I am needing to do the same with my KZ when i fit my RS34 carbs and im looking for ideas / info ?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
09 Nov 2026 15:28
#929011
It’s not the same but I can tell you which wires to connect to which
  • canman
  • canman's Avatar
10 Nov 2026 06:13
#929019
ok Thanks, if i go that route i will get back to you for info, Thank You
