LED turn signals
- Thunderbike550
LED turn signals
11 Jan 2016 13:48
I recently installed led turn signals on the rear of my 1980 kz550a they worked at first but now the left side has gone out. The front is still bulb turn signals. The rear left has just a small amount of power going to it I can barley see it light up.
Do I need to install a new relay or flasher.
Thank you to anyone who can help me figure this out
- redhawk4
Re: LED turn signals
11 Jan 2016 15:46 - 11 Jan 2016 15:47
Normally with LED turn signals you will need to get a specific flasher relay for LED turn signals because they draw far less current than and ordinary bulb and the signals will flash way too fast. I had a Yamaha cafe racer with these on and found a GM module meant for LED signals that worked. However that issue is with turn signals flashing way too fast. Yours sounds like a bad ground connection (a very common turn signal fault) or a failing LED lamp. You could try swapping the units over to see if the problem follows it from one side to the other.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 11 Jan 2016 15:47 by redhawk4.
- kaw-a-holic
11 Jan 2016 16:14
Like Redhawk said, you do need a LED flasher, you can by them at AutoZone. I also have to agree that the flasher does not sound like the issue.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
