timing ?
- stonemaster
timing ?
20 Aug 2010 08:27
I got my overly heat sensitive new digital timing light to work and i got my timing readjusted but I had to rotate the main plate damn near all the way forward to get the marks lined up on 1 & 4. No more room for adjustment, OK for now but the future >>>>????
- Motor Head
Re: timing ?
20 Aug 2010 08:29
You should state the model and year, also stock of otherwise Ignition. The signature in your profile could put up this info with each post.
- stonemaster
- Motor Head
Re: timing ?
20 Aug 2010 09:40
This may sound dumb, but is the point gap correct? If small you will need to advance the plate.
- stonemaster
- TeK9iNe
- What did you do!?!
Re: timing ?
20 Aug 2010 09:57 - 20 Aug 2010 09:57
Set the Dwell angle/point gap first. Clean the points first with clean paper or cloth, + oil free solvent.
Lubricate the point cam felt gingerly.
Turn the engine over by hand until the 1-4 points are at thier widest. insert a .4mm feeler guage.
loosen the 2 point base screws and the point will rest against the feeler guage. tighten the screws back up, making sure that the gap doesnt widen.
Repaet for 2-3 point, then recheck. gaps should be around .35mm after this procedure.
Then set timing.
@ 0 degrees on adjustable digital light, engine should fire exactly on F mark @ around 1000rpm.
GL.
Then set timing.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 20 Aug 2010 09:57 by TeK9iNe.
- Kawickrice
Re: timing ?
20 Aug 2010 10:14
After adjusting points for over 25 years I got smart and bought the dyna, set it and forget it. I could never justify the cost, when points are dead on the bike screams. But in time the performance would diminish and time to readjust. Points are cheap after all compared to the dyna. I put a dyna in last year and loved it so much I yanked the points out of my 650 and put in a dyna ignition and coils. I must say well worth the money in the long run. A dyna might not be for everyone as far as cost but after 25 plus years of dicking with points its well worth it......... My 2 cents
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- stonemaster
Re: timing ?
20 Aug 2010 10:24
TeK9iNe wrote:
thats what I did we'll see, Kawick I will probably go thats as well NEXT yearSet the Dwell angle/point gap first. Clean the points first with clean paper or cloth, + oil free solvent.
Then set timing.
GL.
- Motor Head
Re: timing ?
20 Aug 2010 10:39
Could it be that your light is off? Does it have a built in advance function, knob on back with a scale, or if digital a setting for advance. If so was it at zero when checking? If it has this it could be miss reading. Have you taken it out for a ride yet?
Also there are some posts here with converting to the Kawasaki electronic Ignition, cheap and readily available.
- Kawickrice
Re: timing ?
20 Aug 2010 10:44
When you set them statically how far were they off with the light?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Motor Head
Re: timing ?
20 Aug 2010 10:47
I think the light just popped on, is your advancer stuck in the advanced position? You said you rotated all the way forward, I'm taking that as clock wise looking at the plate?
- bountyhunter
Re: timing ?
20 Aug 2010 12:01 - 20 Aug 2010 12:03
stonemaster wrote:
As the advancers age, they no longer hold the weights fully in at idle screwing up the idle timing set point.
I'll bet your advancer or advancer springs are messed up. Guess how much time I wasted learning that.....:laugh:I got my overly heat sensitive new digital timing light to work and i got my timing readjusted but I had to rotate the main plate damn near all the way forward to get the marks lined up on 1 & 4. No more room for adjustment, OK for now but the future >>>>????
Last edit: 20 Aug 2010 12:03 by bountyhunter.
