Tach pickup
  • hocbj23
  • hocbj23's Avatar Topic Author
Tach pickup
18 May 2010 17:56
#368838
Need some assistance. Swapped the failing stock Kawi ignition for a Dyna S,3 ohm green coils,etc. When u do this swap u lose ur tach so I bought a good aftermarket tach pickup and installed it.Tach works ok up to about 5k rpm and then it becomes unreliable. I have tried moving the sensor location around on the coil wire but still acts a little weird.Anyone have similar issues with a resolution? Thanks much.Bike is 82 kz 1000 csr but has electronic instrument pack instead of stock cable drives.bj
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Tach pickup
18 May 2010 18:07
#368846
"When u do this swap u lose ur tach "... :huh: ?
Whoa, learned something new.... ok...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • hocbj23
Re: Tach pickup
18 May 2010 18:26
#368858
Well maybe I should have stated I lost MY tach.When u put a Dyna S in u no longer need the ICIgniter which is the white connector on ur harness plate.When disconnected My tach no longer works.OK? Take it from there with any tips or advice.Sorry shouldnt generalize.Thanks.bj
  • MFolks
  • MFolks's Avatar
Re: Tach pickup
18 May 2010 19:40
#368903
Is your tach a combo? I mean when a button is pushed it becomes a voltmeter? On my 82 GPz1100 B2 model the left ignition coil has a black wire that supplies the tachometer.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Tach pickup
18 May 2010 19:45
#368911
no tach drive on head/electronic B)
  • hocbj23
Re: Tach pickup
18 May 2010 19:59
#368916
No it is just tach only,no voltmeter.Yep, that is where external tach pickup is installed now-on the black lead on coil one--still acts weird with erratic readings.I even wrapped it in tape thinking it was picking up interference from coil but that didnt help either.Thanks.bj
  • MFolks
  • MFolks's Avatar
Re: Tach pickup
18 May 2010 20:34
#368923
I'd check for a good tight electrical connection and possible loose ground(s). Negative(-) battery terminal going to the engine mounting bolt clean and tight?
No plastic multi pin connectors in the circuit? If so, dis-connect them, spray with contact cleaner(NOT WD-40!!) and re-connect and try again.
  • pgboyd
  • pgboyd's Avatar
Re: Tach pickup
19 May 2010 08:57
#369018
When I replaced my ignition components with Dyna S, there were two tach leads on the new unit. I don't have the instructions in front of me and don't remember the colors of the wires. One wire sent twice the number of pulses as the other wire. The first wire I hooked in to the black wire off the coil and my RPMS were double what they should have been, so changed it to the other wire.
I believe that the Dyna website has the instructions if you're missing them.
My tach works fine now.
Phil
Northern VA
Phil Boyd
Northern Virginia USA
1995 KZ1000P Police Bike
  • MajDSaster
  • MajDSaster's Avatar
Re: Tach pickup
19 May 2010 09:07
#369019
I just had a Dyna S installed on my 81 LTD 1000 and now I have no tach.
Though, considering how many guys I know with bikes that have a speedo only, I have to say that I didn't really miss it yesterday.
Maybe I'll stick a clock on it, unless there is a simple fix to make it work again.
It's a single function tach with no voltage buttons.
Current Ride: 2005 Kawasaki Vulcan 750
4th Ride: 1981 Kz1000 LTD (2008 - Storage)
3rd Ride: Wife (1999 - 2005)
2nd Ride: 1982 Kz1000 LTD (1983 - 2004)
1st Ride: 1977 Yamaha SX-650 (1981 - 1983)
  • hocbj23
Re: Tach pickup
19 May 2010 13:28
#369048
Thanks all.I still have my instructions and they are a bit confusing on the multiple cylinder/2 coil system, but I think we followed them as they were written.Its not that it doesnt work,it just works freaky above 5k rpm.Mfolks, I have removed ,cleaned and tightened every ground wire on the bike more than once over the past two years, and I just made a walk around the wiring harness with a spray can of electrical connector cleaner last week so I think all thats in order.Will recheck the grounds especially at the coils again however. Thanks fo rthe input.bj
  • loudhvx
  • loudhvx's Avatar
Re: Tach pickup
19 May 2010 23:30
#369172
Because the Dyna S extends the dwell to just short of continuous, the factory tach may indeed not work. It expects a dwell of about 120 degrees. There is likely not enough time to allow the coil signal to rise back up to create a pulse for the tach to sense.
You would just need a small adapter circuit to use the factory tach with the Dyna S. I wonder if Dyna sells one. I doubt it would be too hard to make one.
So now you have an aftermarket tach that uses a sensor on the spark plug wire? That should work with the stock igition or the Dyna since it is detecting actual spark. Did you try a different plug wire?
  • hocbj23
Re: Tach pickup
20 May 2010 16:30
#369375
No I am still using the factory tach.The pick up sensor is aftermarket and is on the black coil wire for Number 1-3 coil.Thanks.bj
