Kz750 Ignition on a Kz650
- anakinkenobe
07 Sep 2009 11:57
Hey all i have a 1978 kz650, i swapped an '80 750 motor in it and was wondering if i can keep the 750's ignition and what other parts i would need and how to hook it up..
Thanks
Jason
Thanks
Jason
- anarki650
Re: Kz750 Ignition on a Kz650
07 Sep 2009 12:34
Is the 80 motor electronic ignition? If so you'll need to keep the pick ups (on the plate where the points go for the 650) as well as the advancer from under that cover. You'll need the igniter from the 750 ignition as well. The pick ups will plug into the igniter and the igniter will plug into the coils along with the 12v hot wire that feeds the coils. Should be a piece of cake.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- anakinkenobe
07 Sep 2009 13:00
it is electronic ignition, will my 650 coils work? ill take a pic of what i have, i have no idea what im doing when you say,"The pick ups will plug into the igniter and the igniter will plug into the coils along with the 12v hot wire that feeds the coils."
- bountyhunter
07 Sep 2009 16:10
anakinkenobe wrote:
I believe tyhey will. kawi OEM coils designed to work with points run about four Ohms, I think the ones they made for electronic modulse were more like three Ohms. You can drop a four Ohm coil into a system set up for a three Ohm coil and it should work no problem. The reverse is not always true.it is electronic ignition, will my 650 coils work?
- loudhvx
08 Sep 2009 02:07
There is a chance the points coils will work with the electronic ignition, but the electronic ignition uses a shorter dwell, so hotter coils may be needed to work at higher RPMs. If it revs through to redline at full throttle in gear, then they should be fine. If not, then you may want to look at 3-ohm Accel coils or 3-ohm Dyna coils, or 2.2-ohm Dyna coils, or even new-old-stock 2.4-ohm Kaw coils. It won't hurt to try the ones you have.
The igniter is the little electronic box that connects to the coils and the pickups which are under the points cover. If you don't have one, you can make one:
www.geocities.com/loudgpz/GPZgmHEImod.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- anakinkenobe
29 Sep 2009 07:00
Hey all i have obtained an IC Igniter from an '80 750, wired it in according to a step by step i found and i dont believe i am getting spark so i guess i might as well opt for the dyna ignition just so i have no question as to what i am doin...
- loudhvx
29 Sep 2009 07:57
The Dyna will work better with the stock 650 coils than the factory electronic ignition would, anyway.
1981 KZ550 D1 gpz.
Other links.
Other links.
- anakinkenobe
06 Oct 2009 07:23
Ok so i have been going through the clymers book and i cant seem to set the timing, can anyone dumb it down for me, ive got all of my electronics hooked up i just cant seem to figure out why i am 180 degrees out or how to set it.
Thanks
Thanks
- loudhvx
06 Oct 2009 10:24 - 06 Oct 2009 10:55
anakinkenobe wrote:
What ignition are we talking about? Points, Kaw-electronic, or Dyna?
There are many things that can cause you to be 180 degrees out. How do you know you are 180 out? Are you getting spark now?
Stock 750 ignition will have a pointer that points to the pickup with the black/blue wire when pistons #1 and #4 are near top. The right hand coil will have a black wire going to it and will connect to #1 and #4 plugs. The left hand coil will have a green wire to it, and will connect to the #2 and #3 plugs.
The rotor in the pickups can go on in either direction.
Thanks
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 06 Oct 2009 10:55 by loudhvx.
- anakinkenobe
06 Oct 2009 12:11
stock 750 electronic ignition, it just turns over and doesnt even sound like it wants to fire, ill take a video of it and post it tomorrow
- vintagestyle7
06 Oct 2009 12:23
Get a multi meter and turn the crank with a wrench to see when the coils are firing. This is often referred to as static timing which can be done with a multi meter or a timing light. I have better luck with a multi meter since I also know if my coils are getting 12 volts. There are two wires that feed the coils independtly. Place one multi meter on one and the other on the engine ground. Do this for each one. I wouldn't try starting the bike until you've done this...
My .02
My .02
1979 KZ650 B
1975 CB500 T
1975 CB500 T
- anakinkenobe
06 Oct 2009 15:42
what setting does the multimeter need to be on? is it the wire end or the end where the plug wire is?
