Changing out reg/rec to a combo unit
  • Kawickrice
  • Kawickrice's Avatar Topic Author
06 Sep 2009 15:38
#319563
My charging system took a dump today. On my Z1 I have a separate regulator and rectifier I want to go to a combo unit and was wondering what I need to do to make it happen. I also have one fuse for the whole bike instead of one for every circuit. Any one got a homemade diagram on how to do the regulator, I mentioned the single fuse in case that makes a difference.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Changing out reg/rec to a combo unit
06 Sep 2009 16:02 - 06 Sep 2009 16:06
#319569
@ Z1.... Plug and play for the most part....
www.z1enterprises.com/detail.aspx?ID=1873
You may need the lower unit pending year of your Z1....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 06 Sep 2009 16:06 by Old Man Rock.
  • Old Man Rock
06 Sep 2009 16:07
#319570
Arrrrrrrrrrrrggggggghhh... Again with the images...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
06 Sep 2009 16:18
#319572
In review of the actual images, shouldn't be that difficult to wire in...
Jeff @ Z1 should have the wiring diagram that comes with the units.... PM, maybe he can provide but should be locse to this....
3 yellows for the dyno/stator Vac inputs...
1 green most likely ground...
1 red most likely +12Vdc out...
The unit most likely grounds on the frame as well...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Kawickrice
06 Sep 2009 21:39
#319631
I appreciate the help Rock. I will check with Jeff. I have been thinking of converting to one unit but I just have not had any problems with the old style untill now.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
07 Sep 2009 07:26 - 07 Sep 2009 07:40
#319660
One fuse for the whole electrical system is NOT a good way to go...
EDIT: Just opened your schematic... Holly shit, this is the way it's supposed to be... My bad!
Not sure if you've already posted the problem here in another posting... So how about we start and maybe just fix the problem without the need for converting, or for $120, you replace both, your call...
Anyway, just in case, here's the procedures to test and confirm each of the components... Maybe you've already done so...
There's several ppl here with Electronic/Electrical back grounds that are willing to help out...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Sep 2009 07:40 by Old Man Rock.
  • Old Man Rock
07 Sep 2009 07:38
#319663
just in case.... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
