Relay Fix on Ignition
  • mzandmz
  • mzandmz's Avatar Topic Author
26 Aug 2009 19:44
#316645
Tomorrow I will be putting on the relay to the coils to increase voltage from the old vintage 10.2volts and giving it a wopping 12volts.:woohoo: ,.My question to all those who have done this FIX, Is 10.2volts enough to properly power up the 12volt relay? I know how the relay works, but is that 10.2 going to give the relay enough switching power to keep the contacts together?:huh:
New to Family, 1979 KZ440 LTD
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Relay Fix on Ignition
26 Aug 2009 20:43
#316659
I'm not an electrical guy but I believe what the coil mod actually does is bypass a lot of old wiring to apply direct 12 volts to the coil, so if I'm correct then the relay gets 12 volts direct from the battery and it is sent almost directly to the coils. Someone will chime in if I'm wrong but I believe that's the way it works..... kinda. :)
  • mzandmz
26 Aug 2009 21:03
#316663
Yes it gets 12volts through the relay. My question was according to the diagram you take the same wire that gets the lower voltage due to old wiring/contacts/switches is now used to switch on the relay.And that wire (yellow with red strip)is the one that only has 10.2volts. :dry:
  • bountyhunter
  • bountyhunter's Avatar
26 Aug 2009 22:20 - 26 Aug 2009 22:24
#316676
The wire that read 10.2V did so because of a big honking voltage drop caused by the coil current: stock coils are maybe 4 Ohms, so each one draws 3A. That causes a big voltage drop getting to the coils.
But, that line that previously carried 3A does not in the new circuit: the high current to the coils comes through the relay contacts from a direct feed from the battery. The wire that read 10V before should read over 12V now because it only carries enough current to close the relay which is probably about 0.2A. That will not cause any significant voltage drop.
Last edit: 26 Aug 2009 22:24 by bountyhunter.
  • bountyhunter
26 Aug 2009 22:23
#316677
Pop the wires off the + coil primaries and that wire will magically read 12.6V.;)
No high current = no voltage drop.
  • mzandmz
26 Aug 2009 22:35
#316678
When I checked my voltage at the wire going to my coils(yellow/red stripe) I had the coils disconnected. I use a volt meter red to yellow/red wire and black to the battery ground. 10.2 volts, No coils were connected to draw honken currant. All I was showing was what voltage I was getting fron the battery when is has to go through the ignition switch then the kill switch and to the coils which weren't connected at the time I checked the yellow/red wire. so that beeing the case I still get 10.2 from the yellow/red wire going to relay. The other side of relay will send 12volts to new connection at coils
  • Old Man Rock
  • Old Man Rock's Avatar
27 Aug 2009 03:54
#316691
Guys, he's asking if the 10.2Vdc is going to be enough to activate the relay in which case most probably not for that is a significant drop off from 12Vdc. Expect some on/off relay operations while running....
Forget about the relay for a moment, Question, you measured the Red/yellow @ 10.2Vdc but no mention here (maybe I missed it) of the actual battery voltage measurement while running the engine...
Translation, @ idle for say, if the battery itself measure @ 10.2Vdc as well then this relay mumbo-jumbo ain't going to do a damn thing for you....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • mzandmz
27 Aug 2009 08:28
#316737
Give Oldmanrrock a millon dollors. He hit the nail on the head. But as for the volt check I did it NOT RUNNING. Direct check with key ON from Yellow wire with red stripe NOT hooked to coils,Red side tester to yellow/red Black side tester to Negitive side battery. volt meter read 10.2 Sounds to me like I need to rebuild the switches to rid them of resistance to bring up the voltage to the yellow/red wire to achive closer voltage of 12 or near abouts. NOT 10.2 if thats not going to be enought to keep the relay switch constantly working.
  • PLUMMEN
  • PLUMMEN's Avatar
27 Aug 2009 08:50
#316740
check/clean your electrical connections throughout your harness is the best thing you can do for these bikes,adding a bunch of extra stuff just means more things to leave you stranded on the side of road in my experiance B)
  • mzandmz
27 Aug 2009 09:00
#316742
Thats 100% correct.. I haven't cleaned the switches yet. But when I first got the Bike I took apart every connection and cleaned them, including all groung connections. I live on the coast knowing about moisture problems. Salt in the air reeks havic constantly.
  • mzandmz
27 Aug 2009 14:25
#316788
I got my relay hooked up and Now have 12volts going to coils, Already notice better running condition. Easier starting and smoother running. I was able to make a harness just for the relay so If ever I need to change anything or to put it back the way it was STOCK ,I didn't cut any wires on the original wireing harness so everything is still STOCK just slightly modified. Cool. Mounted the relay next to the voltage regulator,nice fit there and close to the starter solinoid for easy hook-up. Guy at Knechs Auto found the wire plug for the relay($3.00)Relay was $3.00 nice and clean looking. Awsome,:woohoo: .:woohoo: .:woohoo: .:dry:
  • bountyhunter
27 Aug 2009 14:49 - 27 Aug 2009 14:54
#316793
If the battery voltage is OK (above 12V) you should be getting more voltage at that line, unless some other high current load is hanging on it upstream like the headlight. I doubt that would happen for stock wiring, but it might have been modified.
Did you measure the battery voltage directly first?
Remember, if you are truly getting a 2V drop along ANY circuit path, that drop has to be caused by a resistance AND a current flowing. It's possible the old switches have more resistance than original, but current has to be going somewhere to create a voltage drop.... and a 2V drop is a big drop.
Last edit: 27 Aug 2009 14:54 by bountyhunter.
