82' kz550 ignitor and rectifier wiring
- nelson8708
19 Jul 2009 19:36 - 19 Jul 2009 19:57
Well i'm now wiring the bike and have a few questions. Just to make sure i have everything correct before i put power to it i would like a for a few others to check to make sure i have the correct wires going to ground and power.
^click the image to get a better look at it.
Ignitor :
D/G - coil ground (what cylinders should this coil fire?)
B - coil ground ( same Q as above ^)
R/Y - 12v source
Y/B - Ground
Rectifier :
R/W - 12v source ( back to the B+ termial since i think this is the charging wire)
B - Ground
Br - 12v source
Correct or not?
Thanks,
-Nelson
Ignitor :
R/Y - 12v source
Y/B - Ground
Rectifier :
B - Ground
Br - 12v source
Correct or not?
Thanks,
-Nelson
1996 yz125 power with 1982 kz550 engine
1989 240sx Turbo weekend warrior
1993 Civic daily beater
Last edit: 19 Jul 2009 19:57 by nelson8708.
- loudhvx
Re: 82' kz550 ignitor and rectifier wiring
19 Jul 2009 20:30 - 19 Jul 2009 20:34
nelson8708 wrote:
On KZ550 it's normally the left hand coil as you sit on the bike.
nelson8708 wrote:
On KZ550 it's normally the right hand coil as you sit on the bike.
For these wire color conventions to hold true, the advancer rotor has to point the right way. It can go on in two ways. The tip of the rotor should point toward the "Tec" logo on the advancer, instead of away from the logo.
nelson8708 wrote:
The Br wire gets a switched 12v source. It's only on when the ignition is on.
Green fires the coil for cylinders 2&3.Well i'm now wiring the bike and have a few questions. Just to make sure i have everything correct before i put power to it i would like a for a few others to check to make sure i have the correct wires going to ground and power.
Ignitor :
nelson8708 wrote:
Black fires the coil for cylinders 1&4.B - coil ground ( same Q as above ^)?)
nelson8708 wrote:
Yes, correct, but the R/W is to a permanent 12v source. It actually should go to the starter solenoid connection which has the battery cable on it, or directly to the positive of the battery itself.R/Y - 12v source
Y/B - Ground
Rectifier :
B - Ground
Br - 12v source
Correct or not?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 19 Jul 2009 20:34 by loudhvx.
The following user(s) said Thank You: Redman79
- nelson8708
20 Jul 2009 02:37 - 20 Jul 2009 02:38
Do the coils care which primary terminal gets 12v and which one gets ground? I am running a pair of 1998 vulcan 1500 coils and i am getting conflicting anwsers on which terminal gets 12v and which is the ground/ignitor trigger.
thanks,
-Nelson
thanks,
-Nelson
Last edit: 20 Jul 2009 02:38 by nelson8708.
- loudhvx
20 Jul 2009 10:20
nelson8708 wrote:
Sometimes the coils have a + and - labeled on them, but even then I doubt it matters. I think it was just so the wiring would be uniform. If you see the + and - labels, you would use their convention to be safe, but if there are no labels, it does not matter.
No.Do the coils care which primary terminal gets 12v and which one gets ground?
1981 KZ550 D1 gpz.
Other links.
Other links.
- nelson8708
20 Jul 2009 15:35
No + or - labels. Just a black terminal and a green terminal. So unless i find a solid anwser on which is (stock wiring) terminal is power and which is ground/trigger, as long as i have them matching it should be fine?
Thanks,
-Nelson
Thanks,
-Nelson
- loudhvx
20 Jul 2009 16:01
I can't say for sure on Vulcan coils, but I've never seen a regular coil that cared which terminal was positive.
Can you look on a Vulcan wiring diagram? It should tell you which terminal typically goes to the ignitor.
1981 KZ550 D1 gpz.
Other links.
Other links.
- nelson8708
20 Jul 2009 18:45 - 20 Jul 2009 18:49
i haven't had any luck finding one online to DL and find what i need. I found a pic of a smaller (750 i think) vulcan coils and the positive went to the green terminal so for now that is what i'm going with. Even though its a different size bike they use the same TEC brand coils and i would assume that they dont switch terminal colors. Of course this could be the making of a 60$ mistake :blush:
I might make a trip to a local kaw dealer and see if they can help me out. I finished wiring the bike today. So when ever i am able to work up the balls to do so i can attempt to start her.
Last edit: 20 Jul 2009 18:49 by nelson8708.
- loudhvx
20 Jul 2009 18:56
Heh, yeah. What you really want to do is drop in some 81-83 GPZ cams and get some top end out of that thing! :laugh:
1981 KZ550 D1 gpz.
Other links.
Other links.
20 Jul 2009 19:10
Perhaps I overlooked this info, but have the Vulcan coils been ohm-checked to assure the resistance is appropriate for whatever ignition system is presently fitted?
Good Luck!
Good Luck!
- nelson8708
21 Jul 2009 03:40
yeah, the vulcan coils measured out to be 2.8 ohms i believe. I checked before i bought them.
Cams.... :laugh: .....how bout we get this thing running and on the road. Maybe over winter since i have to remove them to change the valve clearance anyways.
One other quick question....the three yellow wire that are coming from the alternator don't have to go to a specific yellow wire on the regulator right? I mean.....their all yellow so it shouldn't matter.
- loudhvx
21 Jul 2009 08:12 - 21 Jul 2009 08:13
nelson8708 wrote:
nelson8708 wrote:
You are correct, sir.
Good planCams.... :laugh: .....how bout we get this thing running and on the road. Maybe over winter since i have to remove them to change the valve clearance anyways.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 21 Jul 2009 08:13 by loudhvx.
- nelson8708
21 Jul 2009 13:43
The questions just keep coming. Now that i finished wiring i might have to go back and change some stuff. On another forum a guy pointed out that the r/y wire isn't a 12v wire. He said that the r/y wire might produce its voltage from the ignitor when the engine is running. Maybe the pick up coils provide the voltage. I went and traced that wire and it doesn't go to a power source.
Ideas?
Ideas?
