HELP ! Grounded Points
  • Hayward
  • Hayward's Avatar Topic Author
  • '79 KZ650
29 Jun 2009 21:32
#303275
While installing new points, I'm doing the static timing and notice I have ground with points (1&4) open or closed. I narrowed it down to black harness wire. I can disconnect in harness where it goes to coil, pull neg. wire off either coil, or turn ignition ON, and it clears ground. What in the world could cause this ? Any help would be appreciated !
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: HELP ! Grounded Points
29 Jun 2009 21:52
#303277
It's been years since I've swapped out my points ignition,but there are isolating washers in there,I believe, where the wires connect onto the points plate...any chance of that being an issue,in your case?
1977 KZ1000 A-1
  • Hayward
  • '79 KZ650
29 Jun 2009 22:13
#303279
No. That was the first thing I thought. Black wire is grounded while disconnected from points. The strange part is, I just set the old points last week with no problems. Is it such a thing as grounded coil ? I pull the black wire from 2&3 coil and the ground on 1&4 clears.?? Sounds like something switched around in wiring.
  • Hayward
  • '79 KZ650
30 Jun 2009 07:27
#303327
Well, since no one seems to know that question, I'll try another. Should the black wire from 1&4 points be connected to the 1&4 coils ? Since I can't figure out which side is (+) and which is (-) in the schematics, does it matter which side the wires from the points go on the coil ?
'79 KZ650C
  • Kawickrice
  • Kawickrice's Avatar
30 Jun 2009 07:47
#303332
Of course the points are grounded they attatched to the points plate that is grounded. If you are using a test light IT should be grounded then when your points open they should show fire. Does that make any since?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Hayward
  • '79 KZ650
30 Jun 2009 07:59
#303337
When the points are open, I should not see ground. I am trying to set the static timing. The ground I'm seeing with meter is with wire OFF points plate.
  • Kawickrice
30 Jun 2009 08:05
#303338
The points are grounded by the nature of how they are attatched. I set my points with a test light. If you ground the test light when the points open, it should show voltage. I have never used a meter to set points, to many leads to try to get right, a test light frees up the hands to do adjustments.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Hayward
  • '79 KZ650
30 Jun 2009 08:12
#303339
I'm going by test procedure in manual. This is just trying to get timing close to 'F' mark before I use timing light. The points are grounded open and closed. The way I see it, they will not fire when grounded. Points on 2&3 are fine - no resistance when open and grounded when closed.
  • Kawickrice
30 Jun 2009 08:22
#303342
There are little phenolic washers where the wires hook to the points. Make sure they are in place. Look at the 2-3 points and make sure the wires are isolated just like 2-3.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Hayward
  • '79 KZ650
30 Jun 2009 08:25
#303343
That is definitely not the problem. The black wire going to the coil is disconnected from the points and is grounded.
  • Hayward
  • '79 KZ650
30 Jun 2009 11:23
#303380
'79 KZ650C
Seems I can't get an answer to any of my questions today. Maybe a detailed drawing or explanation of the last question above would get me going again.
  • DoubleDub
  • DoubleDub's Avatar
30 Jun 2009 12:24
#303388
Pictures are helpful too.
