Mikuni VM 33 Carbs
- Injected
Re: Mikuni VM 33 Carbs
02 Dec 2022 11:32
Hi Steve,
I was wondering where you ended up on the tuning (jetting) on your VM33's?
I ask because I am planning on running the same carbs with a air box and noticed you also using one (not very many examples of them with the air box)
Could you list your setup if you don't mind? (engine CC, head work, exhaust etc.)
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
02 Dec 2022 13:19
1075 was 1015 both Wiseco pistons, mild porting, (Big difference), Andrews 1X cams, V/H exhaust, Dyna S, green coils and K&N air filter.
130 mains, 1.2 air jets, added an extra hole in the emulsion tubes going to 27.5 pilots with the Taylor wires. Too lean before with #25's too rich with #30's. 1.5 slide cutaway. Needles in the center position.
Was fine with with resister wires at #20 pilots.
Pulls great in all gears and no bog at WOT in 5th.
The following user(s) said Thank You: Injected
- Injected
08 Apr 2023 09:46
Bought my carbs like this :
After some clean up and parts replacement there are ready to bolt on :
Pre jetted for 1197cc 10.5:1 motor, big valve head, 420 lift Web Cams shim under, 90CFM port job, running a CV air box, stuffed in a stock looking KZ650 C3 build.
The following user(s) said Thank You: SWest, howardhb
08 Apr 2023 10:01 - 08 Apr 2023 10:02
Last edit: 08 Apr 2023 10:02 by Mikaw.
08 Apr 2023 10:20
They look GREAT gentlemen. Mine were in rough shape. With the help of a couple members they are tunable and work as good as they should. The complaints were "Bogging at WOT". Mine don't do that. Good throttle response throughout the RPM range. Roll on is flawless. Just not as pretty as yours.
I'm just RIDING THE PISS OUT OF THEM.
- Injected
08 Apr 2023 10:59 - 08 Apr 2023 11:03
Mine were rebuilt cheap and nasty... Pine Sol soak and elbow grease
I did replace some rubber parts and fix one float (solder job)
Over all they were not that bad, some jets were seized but I got a torch out and they broke loose.
They just had some normal corrosion on them from years of use.
I did have to fix some PO installed sync ports that were drilled to the wrong size for adapters, redid them at M6 then installed button head Allen bolts with O rings.
I chose VM's over RS flat slides because Larry C had them on his 1200 and he liked them a lot, plus they look more stock than a set of flat slides. I am going for a mostly stock looking build except its a 650 with a 1000 motor in it.
Last edit: 08 Apr 2023 11:03 by Injected.
- Injected
14 Feb 2024 13:42
My Smooth Bores have been sitting on the shelf for quite a while but they are going on the bike this Spring. I must have changed the main and pilot jets 3 times already but have settled on first start jet sizes.
My engine build : 1197cc MTC 10.5:1, 37/31 valves stage 1 ported Z1 head (96CFM int/73CFM ex) RC .425" cams, Custom 4 into 2 exhaust with stock 650/750CV air box
Jetting :
slide cutaway = 1.5
jet needle = #6DJ30
needle clip = #3
needle jet = #O-6
main air jet = #1.2
pilot jet = #25 (TBD ColorTune)
float level = 22.5 mm
pilot air screw 1 turn out? (TBD ColorTune)
main jet = #125 (1&4) #127.5 (2&3)
The exhaust and air box are going to choke it off a bit but the final jetting will be confirmed by a on bike AFR gauge.
Jetting :
slide cutaway = 1.5
jet needle = #6DJ30
needle clip = #3
needle jet = #O-6
main air jet = #1.2
The following user(s) said Thank You: Nessism, SWest
14 Feb 2024 15:14
- Injected
14 Feb 2024 15:25 - 14 Feb 2024 15:25I am going to be running a big oil cooler as the liners are on the thin side. I also have differential mains, one size richer on the center cylinders so that should help with the heat.
The pilot and main selection is a unknown but the AFR gauge should help me pinpoint correct jetting much quicker than in the past.
Last edit: 14 Feb 2024 15:25 by Injected. Reason: sp
- Injected
09 Jun 2025 19:00
I thought I would update this thread since I finally got my 1200 engine running.
My main issue with these 33's is that there is very little jetting info for my combination (air box with dual exhaust) I do think that combination is choking it off a bit as this engine build is pretty straight forward and exactly what you would build for a road race bike or as a side car engine. The guy who ported the head said it was very similar to a award winning vintage series side car engine he built a few years back.
Since these are race carbs all jetting suggestions are for stack/pod/pipes, so richer than what I require.
Generally I think I went a bit rich, which is OK. The air box and dual pipes are more restrictive than I anticipated.
Once I get the idle sorted I will ride it around with my O2 sensor and AFR gauge strapped on, then report back.
11 Jun 2025 08:09Didn't realize this was my thread you were responding to. I think I went back to the 125 mains and not sure of the pilots. Gas milage is SHT at 20 or so MPG. Had it at 42ish before I built the Bike port. I go the 12 miles into town and get 1 gallon each time. It's 24 each time. Somewhere I'm using lots of gas. Plug chops are in my future.1075 was 1015 both Wiseco pistons, mild porting, (Big difference), Andrews 1X cams, V/H exhaust, Dyna S, green coils and K&N air filter.
- Injected
11 Jun 2025 14:35
I just did my initial start up on #25 pilots but its way too rich, going to drop them down to #17.5's. That air box I am running must be way more restrictive than I thought.
I am running stock air screws with the hole thru them so the setting on those would be a maximum of 3/4 turns out.
I will set my needles and mains with my portable O2 sensor and AFR gauge. Plugs chops are fun but there is always some jackass in the way!
