Mikuni VM 33 Carbs
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Mikuni VM 33 Carbs
10 Jun 2019 21:26
#805487
Still have to lower the floats.
  • SWest
  • 10 22 2014
12 Jun 2019 17:58
#805609
Having mini heat waves again this year.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
15 Jun 2019 13:33
#805778
Dropped main jets from 120 to 117.5
Now wondering about 15's
:whistle:
1982 KZ1100-A2 Sleeper 😎
  • SWest
  • 10 22 2014
15 Jun 2019 13:57
#805781
You need to put at least 100 miles on the bike before you make any changes. You don't want to go too lean.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
15 Jun 2019 20:15 - 16 Jun 2019 11:22
#805809
SWest wrote: You need to put at least 100 miles on the bike before you make any changes. You don't want to go too lean.
Agreed! The 17.5's seem good, but I won't know about the 15's unless I give em a shot. Makes sense it would run lean with 20's, but the plugs don't show lean with the 17.5's...and there is no obnoxious popping on deceleration or between up-shifts with them.
Wondering if oil burning may contribute to the engine running well with leaner jets?
Any info I've seen about jetting with a header and other slight mods does not support going lean...
:whistle:
While on the subject of big jets, I picked up a handy little Motion Pro tool that makes changing the pesky things easy when the carbs are mounted on the bike. Motion Pro stopped producing this tool around 2012, but it still shows up in their jet-tool images frequently posted on ebay, though nearly impossible to find.
View attachment
Last edit: 16 Jun 2019 11:22 by daveo.
  • SWest
  • 10 22 2014
16 Jun 2019 19:34
#805883
When I was fouling plugs due to old bad valve guide seals I had to drop down two steps on the pilots. Could be the same thing here only less. Still going to lower the levels 2-3 mm.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
17 Jun 2019 11:06
#805934
Makes sense. The base rings are showing less carbon buildup, and gas mileage is improving.
Nice having this forum available for discussion now-a days, when few bike mechanics are willing to even look at older (but gooder) bikes anymore.
If you have a little mechanical aptitude and the dedication to keep these old contraptions running, the results can be quite rewarding.
:woohoo:
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
21 Jun 2019 21:30
#806242
Been flying around with 115 main jets for a few days, and man oh man. ;)
The plug color is starting to look pretty good. Acceleration is like I can't even remember, and no pops in any direction.
The lean changes probably won't reduce oil consumption much, but I gotta say I am blown a way how the old engine is running now. :evil:
  • SWest
  • 10 22 2014
23 Jun 2019 20:42
#806338
Seems to be cleaning up. I'll keep it this way for a while. B)
  • SWest
  • 10 22 2014
02 Jul 2019 15:51
#806867
Things will change when I put on the new head.
  • SWest
  • 10 22 2014
21 Jul 2019 07:27 - 21 Jul 2019 18:27
#807922
Still need to adjust the float levels. :dry:
Last edit: 21 Jul 2019 18:27 by SWest.
  • SWest
  • 10 22 2014
21 Jul 2019 20:06
#807952
Had to reupload the clip.
