Mikuni VM 33 Carbs
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Mikuni VM 33 Carbs
02 Jun 2019 05:38
#805021
I soldered and drilled the 1.2 jets to .6 after I tried new .9 air jets when I went #20 pilots. I then redrilled them back to 1.0 with 17.5 pilots. Still a touch rich on the bottom so the 15's. I still have the .5's I made out of the .9's to try if too lean off idle.
Those are good prices.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Jun 2019 09:30 - 05 Jun 2019 10:25
#805195
Had a thought after examining spark plugs and checking compression...
Would #3 be lean due to lower compression in that cylinder? If so, would having a richer air jet in just that carb serve to compensate?
Might be from air getting by that manifold at the head. Will be installing a new set this weekend. :)
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
Last edit: 05 Jun 2019 10:25 by daveo.
  • SWest
  • 10 22 2014
05 Jun 2019 13:50
#805205
It would show rich.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
06 Jun 2019 14:15
#805266
Rode 80 miles today after swapping out cylinder three air jet to .5, leaving the others .6's.
Immediate improvement; smoother idle and better throttle response through the entire operation rpm range, with only a slight adjustment to the fuel screw. Hardly any pops now when letting off throttle and between gear shifts.
Will post pic showing plug condition after riding some more miles.
1982 KZ1100-A2 bike
  • SWest
  • 10 22 2014
06 Jun 2019 15:30
#805268
Little job just got larger. :dry:
  • SWest
  • 10 22 2014
06 Jun 2019 20:16
#805280
This is with 17.5 pilots, we'll see what they'll look like with the 15's.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
07 Jun 2019 08:37 - 07 Jun 2019 11:31
#805301
Curious how far your rubber intake boots project inside your air box on 1 and 4, and if the air flow may be somewhat restricted compared with 2 and 3
*Approximately 150 miles later #3 spark plug color appears less-lean, and more as the others:
1982 KZ1100-A2 bike
Last edit: 07 Jun 2019 11:31 by daveo.
  • SWest
  • 10 22 2014
07 Jun 2019 12:43
#805315
Only about an inch. The 15's seem nice but I think I set the float levels too high.
  • SWest
  • 10 22 2014
07 Jun 2019 21:39
#805342
I think I have them too high.
  • SWest
  • 10 22 2014
09 Jun 2019 06:16
#805398
Always wondered what they looked like running. I'll lower them then do a running check on all of them.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
09 Jun 2019 09:56
#805408
Vacuum Carb Sync?
1982 KZ1100-A2 bike
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
09 Jun 2019 11:09
#805414
Watched your clear-tube video...cool. Hadn't thought of that. :huh:
Before installing new manifolds this week, I will do a running level test. Have floats at 18mm. and was contemplating resetting them back to 17mm. (+/- 1mm) per Mikuni spec for RS carbs.
Having one different air jet in the set significantly improved the starting, idling, and overall throttle response of my engine. Now the #3 cylinder plays a whole lot better with the others.
RS Flat Slide Smoothbore carburetors:
:woohoo:
1982 KZ1100-A2 bike
