Mikuni VM 33 Carbs
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Mikuni VM 33 Carbs
27 Apr 2017 22:01
#760451
None better place besides home...
Sounds like you are there :)
1982 KZ1100-A2 Sleeper 😎
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
06 Jun 2017 14:30
#763731
The bike finally "leaned out." It had to get pretty hot to do it. I got back home and adjusted the timing and pilot screws. Much better. The bike pulls harder and some of the noise has gone away. I'd rather not go back to the #70's. I may go leaner still. I'll do the cam bearings and readjust.
  • SWest
  • 10 22 2014
28 Jun 2017 15:21
#765601
The oppressive heat has lifted at least for a few days. Got a few things to get done while I have the chance in the mornings.
  • SWest
  • 10 22 2014
28 Jun 2017 17:51
#765612
Test ride tomorrow.
  • SWest
  • 10 22 2014
30 Jun 2017 06:33
#765723
Took a ride up and down the HWY. The main thing I wanted to know is if it would bog on roll on. It doesn't. The ;pilots are less responsive though.
In the old Clymer manual I had that was stolen years ago there was a performance section that showed how to change the cutaway from 2.0 to 1.5. The one I bought in the 90's has it listed on the cover but that section is missing. It involves filing the bottom of the slides but I'm having trouble finding it online. Anyone have a old Z1, Z1a, Z1b Clymer on their shelves? The early Z1's had 2.0 slides and this was a common mod at the time.
As it stands now, it's obvious I need smaller pilots with the larger mains. I'll pick some up on Monday.
  • SWest
  • 10 22 2014
02 Jul 2017 17:48
#765928
Checked the plugs. I'll pick up #55 pilots tomorrow. Still a little rich. I'm going to add this guy to my thread. Good advice.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
02 Jul 2017 18:39 - 02 Jul 2017 18:46
#765936
No eBay APP ID and/or Cert ID defined in Kunena configurationAnything like this?
Last edit: 02 Jul 2017 18:46 by daveo.
  • SWest
  • 10 22 2014
02 Jul 2017 18:56
#765937
The one I had was from the 80's.
  • SWest
  • 10 22 2014
03 Jul 2017 20:25
#766009
I might put them in tomorrow. The bike runs great but I think it could be leaner.
  • SWest
  • 10 22 2014
07 Jul 2017 11:53
#766317
I think it's running lean midrange and that's when it's burning oil.
  • KZB2 650
  • KZB2 650's Avatar
09 Jul 2017 10:03
#766478
Hey Steve don't 2.0 slides had a bigger cut away than the 1.5s so you can file 1.5s to make em 2.0s but not the other way around ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • 10 22 2014
09 Jul 2017 11:40 - 09 Jul 2017 11:51
#766486
The way I understand it, you can file .5mm off the bottom and make them 1.5. To make them 2.0 you have to make the cutaway taller.
Last edit: 09 Jul 2017 11:51 by SWest.
The following user(s) said Thank You: KZB2 650
