Mikuni VM 33 Carbs
- daveo
Re: Mikuni VM 33 Carbs
17 Nov 2016 18:58
:huh: What difference does lowering the fuel levels make?
1982 KZ1100-A2 Sleeper 😎
17 Nov 2016 20:18
Leans out the mixture.
18 Nov 2016 03:23 - 18 Nov 2016 03:57daveo wrote: :huh: What difference does lowering the fuel levels make?
The carb is designed to best perform with a certain specified level of fuel inside the float bowl.
A too high fuel level results in an excessively rich mixture throughout the throttle range.
A too low fuel level results in an excessively lean mixture throughout the throttle range.
Here's a link to a fairly comprehensive thread regarding 33 smoothies:
Click > www.kzrider.com/forum/3-carburetor/16281...?limitstart=0#162815
Last edit: 18 Nov 2016 03:57 by Patton.
18 Nov 2016 06:27Patton wrote:daveo wrote: :huh: What difference does lowering the fuel levels make?
Very interesting but he is asking about his flat slides. My 33's are set up differently but I'll read on and maybe learn something. :whistle:
- daveo
18 Nov 2016 14:23
I set the floats at 17 mm +/- 1 mm per Mikuni Flatslide instructions, as I imagine most folks do. :whistle:
Would think there would be clear-tube method instructions somewhere for these carbs, but I have not been able to find any. :evil:
Any leads?
Any leads?
18 Nov 2016 16:11
I would check them all with the clear tube to see if they are all the same.
- daveo
19 Nov 2016 15:25
Just had our first cold day with snow. Perhaps another few rides before its over for another season here.
Thanks Steve, I'll check that...the last time was a few months ago.
Just curious, have you ever considered getting a set of the Flat Slide carbs for your 900?
19 Nov 2016 20:15
It's a 1015 with cams and such. I've thought about it but would rather invest in other improvements first.
- daveo
19 Nov 2016 21:39 - 20 Nov 2016 08:55
I went the RS36, though other members suggested the RS34 would be the better size for my engine. Thought about getting a used set to test, then keep whichever set works better.
The fuel levels were very-close across the set.
Last edit: 20 Nov 2016 08:55 by daveo. Reason: Revise text and change pic
- daveo
22 Nov 2016 07:57daveo wrote: I went the RS36, though other members suggested the RS34 would be the better size for my engine. Thought about getting a used set to test, then keep whichever set works better.
Can't help it...I did it again. :pinch: One PO set of RS34-D21-K will surely arrive the day we get blasted with snow. :lol:
25 Nov 2016 19:02
Reading that thread saying the 33's are slow at low RPM got me to take this clip. Slow?
28 Nov 2016 20:10
Rather than starting a new thread I decided to put it here. May have to tweak the carbs so it will rev better.
